Converting from OBD0 to OBD1
Old 10-25-2004, 08:34 PM   #1
Guy
Rep Power: 20 Guy is off the scale
Send a message via AIM to Guy Send a message via MSN to Guy Send a message via Yahoo to Guy
Basically the situation is that im tired of the obd0 distributor. I just snagged a new one from distributor king about a month ago and its already throwing a code 9 from it. So What im looking to do is convert my obd0 b16a to an obd1 setup. For the past hour ive been researching this and a few discrepancies come up. Most everything ive read says that ill need a conversion harness to deal with the wiring. The consensus also agrees that ill need an obd1 ecu (p28 i imagine) as well as an obd1 distributor, here is where it gets fuzzy. Ill list the things that ive read that i may or may not read: OBD1 Injectors, OBD1 idle air control valve, OBD1 Intake manifold, OBD1 throttle body, etc.
Now http://www.jkobdconversionharness.com/mpc/...0to%20OBD1.html tells me that ill only need the initial three things. Im kind of worried because i called a shop i used to frequent for a price estimate and they told me that parts and all it would cost 1500 and if i sourced the parts it would be 750 in labor, which seems way too expensive to me.
Ideally I'd like some clarification from those of you who have performed this conversion and are farmilliar with it, as opposed to people who will just tell me what theyve heard from people.
thanks in advance
-Jeremiah
1990 Honda Crx
1990 Mazda Miata
1992 Nissan NX2000
1995 Ford Mustang Cobra
2005 Toyota Prius
Guy is offline   Reply With Quote
Old 10-25-2004, 09:17 PM   #2
The Trisexual
92civicb18b1's Avatar
Ride:  2007 Civic, 1995 Jeep Grand Cherokee
Rep Power: 122 92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of
Send a message via AIM to 92civicb18b1 Send a message via Yahoo to 92civicb18b1
Those are very minor things it seems you need to do, don't take it to a shop for such little work. It's like 2 hours of work minus wiring..if you're slow.
I've never done it so I don't know much about it but I suppose you would need the complete intake manifold off and obd1 car, injectors, distibutor and ecu.
All of those parts can be had for less than 500 bucks and can be done over the weekend easily.
DO NOT PM ME WITH TECH QUESTIONS!!!
Current Rides
1992 Chevy S-10 Ext. Cab
Previous
1992 Civic DX Hatch
= 1994 B18B1 Turbo
Rebuilt Garrett .60/.48 T3, log style mani and DIY downpipe, DSM 440's, kteller IC piping, JRC Intercooler, Home Depot style oil lines, HKS BOV, Crome Tuned,
253whp
1994 Civic VX Hatch, 1992 b18a1 swap
1993 Civic CX Hatch, 2000 B18b1
92civicb18b1 is offline   Reply With Quote
Old 10-25-2004, 09:18 PM   #3
GSRCRXsi's Avatar
Rep Power: 84 GSRCRXsi is a jewel in the roughGSRCRXsi is a jewel in the roughGSRCRXsi is a jewel in the rough
thats way too much to charge you when you can do it yourself. and with conversion harnesses its really easy.
there is one company that makes conversion harnesses for the distributor as well. but you have to use their ecu harness too. i cant remmeber where i saw it maybe someone else can chime in on that.
obd1 injectors, IACV, intake manifold are not needed. IACV is not OBD dependednt, and you can keep the stock injectors as long as you keep the resistor box. you will however need to use the obd1 throtte body so you can use the obd1 map sensor. obd0 and obd1 maps are slightly different. you can run it on the obd0 one but its really best to use the obd1 one.
only things you will really need are obd1 distributor, obd1 ecu, obd1 map sensor, conversion harness(es), and some wire and a soldering gun.
im not positive on the whole deal with the alternator but im fairly sure you can use the plugs from one alternator on the other so it will all plug and play.
91 CRX si
95 Integra LS
Originally Posted by 90 accord
i have a lady, of over a year and a half now, and she likes the plug more
get a free iPod, yes it works!
get a free flatscreen, yes it works!
Please give what you can to the Tom Cote Medical Fund
http://honda-tech.com/zerothread/1828476
Old 10-25-2004, 10:12 PM   #4
Guy
Thanks for the comments thus far, keep them coming as id like to be able to draw on as much of everybodys experience as possible.
Not sure if it would make a difference, but i am currently using a skunk2 intake manifold
thanks
1990 Honda Crx
1990 Mazda Miata
1992 Nissan NX2000
2005 Toyota Prius
Old 10-25-2004, 10:56 PM   #5
Rep Power: 28 Bl6CRX is off the scale
Send a message via AIM to Bl6CRX Send a message via Yahoo to Bl6CRX
Actually, you don't need the obd1 throttle body or map sensor, the harness plugs are the same between the years. The only thing is that you must match the obd of map with the obd of tb. But, you do not need to use an obd1 TB to convert to grey plug (obd 1). Also, I ran mine with the obd 0 map/tb and noticed no difference when I switched to an obd1 map/tb. In addition you need the obd 1 or 2 fuel injector plugs/clips, and a 4 wire 02 sensor, if you can't find a used oem one, (and you sure don't want to pay for it new) you can run the bosche one. Also add some shrink wrap to the list of materials and of course electrical tape. Furthermore, you can run an obd 2 distributor, the only difference is the pin locations on the plugs of the dizzys, the obd2 uses a two plug design and the obd1 uses a 1 plug design (I believe that is the correct way around). Honestly its really no big deal, or too much work, you will recieve instructions and just follow them for proper pin/splice locations for 02 sensor wires, vtec oil pressure, vtec solenoid, etc... The main thing is just make good soldered connections and shrink wrap them where you can, its just basic wiring
Bl6CRX is offline   Reply With Quote
Old 10-25-2004, 11:08 PM   #6
GSRCRXsi's Avatar
the reason i say you need a new TB is cause you need the new map sensor. obd0 is 1.7 bar, obd1 is 1.8 bar. i know the plugs are the same but thats not the issue. the differences in the sensor are the issue.
91 CRX si
95 Integra LS
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
