Crx b16 problems
Old 01-19-2004, 12:58 PM   #1
Rep Power: 0 b18c1civic97 has a little shameless behaviour in the past
Send a message via AIM to b18c1civic97
We finished putting in the b16 into the crx, and got the car running but we bumped into a few problems. This is the first time me and my buddy have put a motor in a car, and its been fun and you guys have been great help so far, so here it goes. First off the car gave three different cel codes, a code 7, 14 and 22. The motor was a b16a with a pr3 ecu. 2nd problem that we bumped into is that the motor has no power at all, and feels like its going to die every time you start accelerating too much. Right now the car has no exhaust, and I had a friend tell me part of lack of power was due to not enough backpressure, but I don't think that would make the motor lack this much power. Any help is greatly appreciate it, no flaming though please, I'm trying to learn as I go. Thanks guys
b18c1civic97 is offline   Reply With Quote
Old 01-19-2004, 01:08 PM   #2
Rep Power: 13 SubCultureNM is off the scale
The lack of back pressure won't cause your power problem. This seems obvious, but are you sure you have your plug wires in the proper firing order? We did our B16A swap on Saturday and that was one of our issues. It's easy enough to get them mixed up.
Check the easy things first!
Brian
SubCultureNM is offline   Reply With Quote
Old 01-19-2004, 02:40 PM   #3
Rep Power: 30 StarBellieAngel is off the scale
Send a message via ICQ to StarBellieAngel Send a message via AIM to StarBellieAngel Send a message via MSN to StarBellieAngel Send a message via Yahoo to StarBellieAngel
i'm not too familiar with this swap, but when my car was doing the same thing it was caused by a vacuum leak... are all of the hoses hooked up properly?
<span style=\"font-family:Tahoma\"><span style=\"font-size:10pt;line-height:100%\"><span style=\"color:black\">..::Bl<span style=\"color:red\">a</span><span style=\"color:black\">ck Wi</span><span style=\"color:red\">d</span><span style=\"color:black\">ow g</span><span style=\"color:red\">2</span><span style=\"color:black\">::..</span>
<span style=\"color:gray\">swapped~&amp;~ dropped
90 integra LS ~ B16A</span></span></span></span>
<span style=\"color:gray\"><span style=\"font-size:10pt;line-height:100%\">··¤(`×[¤<span style=\"color:red\"><span style=\"font-family:Tahoma\">if you don't like oral sex, shut your mouth!<span style=\"color:gray\">¤]×´)¤··</span></span></span></span></span>
StarBellieAngel is offline   Reply With Quote
Old 01-20-2004, 03:01 PM   #4
We got vacuum info off of a site, but it was a little difficult to read. Anybody have the vacuum diagrams for a b16 into a crx si, just to make sure we got it right, any help of someone is appreciated.
Old 01-20-2004, 04:35 PM   #5
what site did you get the diagram from? i'll look for one... and also... another thing to check is proper idle speed... sounds like something wrong with the fuel system... almost like it's getting too much gas when you punch it, and it's not compensating. i wish i could help on the CEL codes, but i can't... i'm not good with that stuff. (i'm going to buy a code reader here in a few days, since we'll be finishing my swap)
this link may be helpful to you
ECU CODES
To find out what each code means, check this table:
1) Primary oxygen sensor- Defective circuit or unplugged/ Defective sensor
2) Oxygen sensor "B" - Defective circiut or unplugged/ Defective sensor
3) MAP (Manifold Absolute Pressure) Sensor - Defective circuit or unplugged/ Sensor
4) CKP (Crankshaft Position Sensor) - Defective circuit or unplugged/ Defective sensor
5) MAP (Manifold Absolute Pressure) sensor -Mechanical problem/ Disconnected piping
6) ECT ( Engine Coolant Temperature) Sensor- Defective circuit or unplugged/ Sensor
7) TP (Throttle Position) Sensor -Defective circuit or unplugged/ Defective sensor
8) TDC (Top Dead Centre) Sensor -Defective circuit or unplugged/ Defective sensor
9) CYP (Cylinder) - Defective circuit or unplugged/ Defective sensor
10) IAT (Intake Air Temperature)sensor- Defective circuit or unplugged/Defective sensor
12) EGR (Exhaust Gas Recirculation) -Defective circuit or unplugged/ Defective sensor
13) Atmospheric Pressure Sensor - Defective circuit or unplugged/ Defective sensor
14) IAC (Intake Air Control) Valve- Defective circuit or unplugged / Defective sensor
15) Ignition Output Signal - Missing or defective ignition output signal
16) Fuel Injector System - Defective circuit or unplugged/ Defective fuel injector
17) VSS (Vehicle Speed Sensor) - Defective circuit or unplugged/ Defective sensor
19) Automatic transmission lockup control Solenoid Valve- Defective circuit or unplugged/ Defective solenoid. A/T Only.
20) Electronic Load Detector - Defective circuit or unplugged/ Defective sensor
21) VTEC Solenoid Valve- Defective circuit or unplugged/ Defective solenoid
22) VTEC Oil Pressure Switch - Defective circuit or unplugged/ Defective switch
23) Knock Sensor - Defective circuit or unplugged / Defective sensor
30) Automatic Transmission Signal- Defective circuit or unplugged/ Defective sensor
31) Automatic Transmission Signal "B"- Defective circuit or unplugged/ Defective sensor
41) Primary Oxygen Sensor Heater- Circiut malfunction
43) Fuel Supply System - Defective or malfunctioning Fuel Supply Sytem
45) System too lean or too rich - Malfunction in the fuel monitoring systems
48) LAF (Lean Air Fuel) sensor - Defective circuit or unplugged / Defective sensor
54) CKF (Crankshaft Speed Fluctuation) sensor- Defective circuit or unplugged / Defective sensor
61) Primary Oxygen sensor circuit- High/ Low Voltage, Or slow response
63) Secondary Oxygen Sensor circuit- High/ Low Voltage, Or slow response
67) Catalyst System Efficiency Below Threshold- Malfunctioning catalyst system
70) Automatic Transmission - Malfunction with Automatic Transmission Controls
71-74) Random misfire in Cylinders 1-4- Condition present Creating Misfire
80) EGR (Exhaust Gas Recirculation) Insufficient Flow Detected
86) ECT (Engine Coolant Temperature) Circuir Range / Performance Problem
90) Evaporative Emissions Contrlo System - Leak Detected In Fuel Tank Area
91) Fuel Tank Pressure Sensor- Low Input
92) Evaporative Emission Control System Control System- Insufficient Purge Flow
it seems to me, that the first two will cause the problem.
i boldfaced the CEL codes you said the ecu was throwing, and left the rest so you could copy and paste or print for your info. hope it helps to fix these things... if not, i'll try to help you out some more!!!
Old 01-20-2004, 08:33 PM   #6
http://tech.hybridgarage.com/tech/manuals/...rvicemanual.pdf
The vacuum lines we used was in page 115 because it seemed to resemble the most to ours. I'm looking everywhere for an actual b16 vacuum diagram, but no luck. I'll try to post pics of the swap to see if there is any mistakes that could be pointed out.
Old 01-20-2004, 08:35 PM   #7
Unhappy
Also thanks for the help, at the other forums that I used to use everyone seemed to go out of their way to make fun of people trying to learn. You guys are awesome :P
Old 01-20-2004, 08:42 PM   #8
Awesome found this after some more searching, its too dark and cold to check it today, but I'll check it tomorrow after work, see if maybe the vacuum lines are wrong. The little part that goes in front of the intake manifold that has the vacuum line that runs into the intake tube, do I need to connect that part? because I'm using a cheap intake for the time being that doesn't have a hole for this part. Do I need this or can I just not use it without affecting performance. Once again, thanks guys
Old 01-20-2004, 08:49 PM   #9
there are so many b16's it's kind of rediculous sometimes.
try looking in a manual for a 97 civic Si. i don't know if this will help as far as vaccuum lines go, since it's a completely different car... maybe if you cross ref with the manual for your Civic (like the helm's or hayne's)
i don't have either... i'm trying to get my buddy to steal the honda's manual for my car, and the b16 hehehe
Old 01-21-2004, 11:04 PM   #10
Rep Power: 13 Captinb16 is off the scale
I dont know if your in california or not but alot of that is just emmisions bs. There are only like 3-4 vacum lines that need to be ran. Map, FPR to the back of the intake manifold, theres like 2 others I dont remeber soory to tired. good night..
Captinb16 is offline   Reply With Quote
Old 01-23-2004, 12:05 AM   #11
Rep Power: 0 crxguy is off the scale
Unhappy
i need the firing order 4 a 1 gen b16a
crxguy is offline   Reply With Quote
Old 10-17-2006, 10:44 PM   #12
Rep Power: 0 canemode is on a distinguished road
The firing order on my B16A is 1,3,4,2 hope this helps
canemode is offline   Reply With Quote
Old 10-18-2006, 07:46 AM   #13
The Harvester Of Sorrow
Ride:  91 CRX SI / 92 Prelude SI / 07 Civic SI Sedan
Rep Power: 7 HONDA_PARTS_GUY is on a distinguished road
StarBellieAngel,
Just for clarification, not to be a jerk, they didn't produce a SI in 1997. Just didnt want him to go on a wild goose chase.
HONDA_PARTS_GUY is offline   Reply With Quote
Old 10-18-2006, 10:24 AM   #14
CRXSIR1's Avatar
Ride:  1990 CRX Si
Rep Power: 14 CRXSIR1 is an unknown quantity at this point
Send a message via Yahoo to CRXSIR1
Default Firing order
CRXSIR1 is offline   Reply With Quote
Old 10-27-2006, 01:32 PM   #15
HydroLockeD Type-S GuY
TommYnY's Avatar
Ride:  02 RSX bent rod...94 b16 CiviC Hatch
Rep Power: 7 TommYnY is on a distinguished road
Send a message via AIM to TommYnY
i dont know if this is in the right section sorry moderators if it isnt.....i have very similar problems as b18c1civic97...only thing different is my obd 0 b16 is in a 94 obd1 dx hatch. i came across a obd1 pr3 ecu from a 92-93 jdm integra xsi and thought it wound be best for my application and is currently the ecu in the car. just like civic97 though i floor it and it just sputters like crazy like the mixture is extremely rich and its flooding itself. when thihs happens i turn off the car and wait a min and turn it back on and it revs freely. i just checked the cel codes 5 minutes ago and i have 3 5 7 10 and 41(map,map,tps,iat,o2)...my question is could these codes show up from my vacuams being wrong or are they defective sensors? if the sensors are defective what do i replace them w/ obd0 or obd1 or obd2 b16 sensors?.....
also..when i am moving around vacuam hoses or disconnecting sensors is it necessary to unplug my ecu to reset it?
im going to post pics of the manifold soon to be more specific as soon as i get batteries for my camera...the previos owner said he changed the intake manifold to a obd1 del sol b16 manifold but i dont know about that...
all resposes and any input will be greatly appreciated...
TommYnY is offline   Reply With Quote
Old 10-27-2006, 01:35 PM   #16
TommYnY's Avatar
i just realized i def put this in the wrong section being that i got a eg......sorry mods!!!
Old 10-27-2006, 02:01 PM   #17
TommYnY's Avatar
thats the manifold..im no photographer! all input is greatly appreciated!!!!
Old 05-06-2007, 05:36 PM   #18
Ride:  95 honda del sol
Rep Power: 8 delsol_racer is on a distinguished road
Default jdm b16
i have a jdm obd0 b16a engine dat will start up but the problem is dat it red lines at 3000-3500 don't know what to do so any one knows what to do tell me please
delsol_racer is offline   Reply With Quote
Old 05-07-2007, 10:19 AM   #19
goldgeen90ef
Ride:  96 civic cx b18c-r,95 celica battle daily grinder, chuck taylors
Rep Power: 16 goldgreen90ef has a spectacular aura aboutgoldgreen90ef has a spectacular aura about
myspace
prob. wrong dizzy or dizzy wiring, had same problem w/ my old hatch, it was the wrong dizzy
goldgreen90ef is offline   Reply With Quote
Old 05-07-2007, 02:53 PM   #20
kool thanx but what about codes my ecu have been punching out 6,9,10 so does vtec kick weather codes are present or not
TONS of parts for sale B16, GSR, Type R Envy_Motorsports Parts: For Sale/Trade/Wanted 25 10-16-2008 01:08 AM
B16 Running Problems possessed imports Engine Building 12 06-02-2003 04:38 PM
Vaccum Problems On B16 90integb16a HYBRID -> ED-EF / DA 1 05-08-2003 12:43 PM
B16 Problems Vtec_si HYBRID -> EG-EK / DC 2 04-16-2003 05:22 PM
B16 Problems Tetsuo221 Engine Building 5 03-06-2003 10:16 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
