crx build....which pistons are better?
Old 02-21-2006, 08:54 PM   #1
lil_red_si is off the scale
Send a message via AIM to lil_red_si Send a message via Yahoo to lil_red_si
Thumbs up
<span style="font-size:10pt;line-height:100%">ok so here it goes......i have a d16a6 completely stock....i want to rebuild it and replace all seals and gaskets and what not.....now i have a brand new set of d16y8 pisotns with new rings and new d16z6 pistons with new rings......if i use d16z6 rods...which pistons will be better for the motor....i intend to keep the si head (no mini me shyte) and would it also be better to use the d16a6 rods or the d16z6 rods...and finally what kind of cam is the best to use for power throughout most of the powerband for my si head....links would be appreciated....thanx guys</span> [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
<span style=\"font-size:10pt;line-height:100%\"><span style=\"color:#FF0000\">new project!: 1989 crx si.....d16a6 block..all new gaskets, seals and bearings replaced and now BOOSTED!!!&gt;.....SAAB T3 TURBO....HF MANIFOLD...SAAB 2&quot; INTERCOOLER PIPING....DSM BLOW OFF VALVE....SAAB FRONT MOUNT INTERCOOLER.....BOOST BABY BOOST</span></span>
lil_red_si is offline   Reply With Quote
Old 02-21-2006, 09:38 PM   #2
jlicrx's Avatar
jlicrx has a brilliant futurejlicrx has a brilliant futurejlicrx has a brilliant futurejlicrx has a brilliant futurejlicrx has a brilliant futurejlicrx has a brilliant futurejlicrx has a brilliant futurejlicrx has a brilliant futurejlicrx has a brilliant future
<div class='quotetop'>QUOTE(mr.SI @ Feb 21 2006, 07:54 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
D16Z6 and D16Y8 rods are the same (all D16 rods except 86-87 D16A1 are the same) - both Z6 and Y8 pistons will lower your compression ratio - Z6 will be about 8.4:1 and Y8 will be about 8.7:1 - compression lowers due to the larger combustion chamber in the A6 head
ZCspeed Racing
jlicrx is online now   Reply With Quote
Old 02-25-2006, 02:59 PM   #3
so will it be better to leave my pistons i have in the a6 in and just replace the rings? i want good compression for all motor but wanted to know if swapping over the pistons would help.....trying to make the most power for all motor d16a6...might even make it an auto-xer.....let me know [img]style_emoticons/<#EMO_DIR#>/biggrin.gif[/img]
Old 02-25-2006, 03:13 PM   #4
jlicrx's Avatar
<div class='quotetop'>QUOTE(mr.SI @ Feb 25 2006, 01:59 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
if you want to raise the compression a little, use the PM7 or P29 pistons from the DOHC ZC or 88-89 Integra D16A1 - compression will be about 10.8:1
ZCspeed Racing
