This is a discussion on CRX GSR issue Help in the HYBRID -> ED-EF / DA forum
So ive noticed that when the 88 crx si with a B18c gsr swap gets warm the idel goes up and down from 600 to 900 but i wasent to worried about it, I did clean the IACV just to see if it would help ...
| | #1 |
| So ive noticed that when the 88 crx si with a B18c gsr swap gets warm the idel goes up and down from 600 to 900 but i wasent to worried about it, I did clean the IACV just to see if it would help and no . O well right. So I go to smog it today and they cant run the full test, Not only did it fail the HC (220 allowed mine was 440) at idle but at fast idel 2500-2800 it runs for about 30 seconts into the test then will drop the rpm alot, enough to drop way out of range then its back up, it does this about every 5 seconts so it failed there also. but when driving it it runs great. This is only while sitting running. Things Ive tried. cleaning IACV, spraying vacume hoses/intake with starter spray to see if I can find a vaccum leak, open the coolent bleed valve on the block while the car is running to make sure theres no air in the line. I did this with the heat in the hot position but fan motor off |
| | #2 |
| | #3 |
| In the above video I put my foot on the gas to bring the rpms up, but if I try to hold it there that is when it drops and comes back up and then drops again , then comes back up |
| | #4 |
| | #5 |
| no ideas? |
| | #6 |
| fitv? |
| | #7 |
| it could be your cams if you have performance cams but i think your on the right track with the concern of a vacuum leak. Are u throwing any kind of codes or anything? |
| | #8 |
| Ohm out your tps sensor |
| | #9 |
Similar Threads | ||||
| big issue!! | b303monster | Civic and del Sol - EG and EK | 25 | 02-27-2011 06:18 PM |
| IAT issue | mdlax1 | ECU's, Electronics, and Tuning | 8 | 08-01-2009 04:12 PM |
| RPM issue | mintoxik | Civic and del Sol - EG and EK | 21 | 03-03-2009 03:36 PM |
| Idle Issue / ac issue | cantbetouched24 | General Tech and Maintenance | 1 | 04-28-2008 11:38 PM |
