CRX MAIN RELAY AND FUEL RELAY
Closed Thread
Old 07-29-2004, 12:04 PM   #1
Rep Power: 16 CReX123 is an unknown quantity at this point
Wink
Can someone please tell me where i can find the Main relay and the fuel relay in my crx. I have an 88 HF, Dont know if that makes a difference or not, But please let me know where they are so i can check them to make sure they are good. THANKS.
CReX123 is offline
Old 07-29-2004, 12:13 PM   #2
thistownsucks...
hybrid89's Avatar
Rep Power: 33 hybrid89 will become famous soon enough
Send a message via AIM to hybrid89
in the main fuse box under the dash.
matt
id rather have a hondata and a stock block
then a sleeved, pistons/rods combo and a hack or fmu
hybrid89 is offline
Old 07-29-2004, 12:26 PM   #3
I found out where the Main relay is, but does anyone know, EXACTLY, where the fuel relay is?
CReX123 is offline
Old 07-29-2004, 11:25 PM   #4
Rep Power: 11 JODYG35950 is off the scale
The main relay operates the fuel pump also!!
JODYG35950 is offline
Old 07-30-2004, 03:04 PM   #5
Ride:  06 Chevy Silverado
Rep Power: 88 Jeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud of
Send a message via AIM to Jeef
This is not Swap-related. This is the Swap-related forum.
Try again in the right forum.
Ex 89 crx si,91 & 95 Civic owner.
06 Silverado RCSB 20's, 2/4" Belltech lowering kit, waiting for 2 more cylinders, 1.9 more liters, and 208 more hp engine swap.
Jeef is offline
Closed Thread
