CRX mini -me
Old 10-11-2007, 07:25 PM   #1
ambitious...but rubbish
hatukazi's Avatar
Ride:  91 Si hatch GSR swap
Rep Power: 17 hatukazi is a jewel in the roughhatukazi is a jewel in the roughhatukazi is a jewel in the roughhatukazi is a jewel in the rough
myspace
Question CRX mini -me
My best friend is close to completing his mini-me swap on his 91 crx Si.
done so far is:
head and head gasket from 98 HX (installed)
intake manifold and throttle body from 98 HX with injectors from 91 Si (installed)
ECU from 98 HX with conversion harness from rywire.
?'s I read on here that the Si distributor bolts right on a Y8 head or use the newer one from HX and re-plug it?
which timing belt to use? I have heard D15b and D16Y8 both and need to pick one.
I have also heard an adjustable cam gear is needed, but if I remember right they were using a Z6 ECU.
he also just got a header and I didn't take the one off my old HX so I dont remember 1 or 2 02 sensors?
we are so close to finishing this and want to get it right the first time
thanks for the help in advance .....
hatukazi is offline   Reply With Quote
Old 10-13-2007, 02:28 PM   #2
hatukazi's Avatar
myspace
OK before hw wastes his money on this, we found a timing gear on Egay that comes with a timing belt.
its a 5 bolt adjustable cam gear aluminum, the timing belt that comes with it fits 96-00 1.6L engines. please we need to know if this will fit correctly?
Old 10-14-2007, 01:42 AM   #3
hatukazi's Avatar
myspace
no one does mini me's anymore???
Old 10-16-2007, 08:11 PM   #4
Grandpa
88blacksi's Avatar
Rep Power: 7 88blacksi is on a distinguished road
It's not that no one does mini me anymore. Its that the motor are getting hard as hell to find. I was planning to do all motor a6/y8 and read specs here that it will handle 200hp on stock build with oem parts and tuning. I need more. So i upgraded to b series all motor.
88blacksi is offline   Reply With Quote
mini engineer makes robots from minis Dman1100 Members' Lounge 8 04-25-2004 01:19 AM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
