Which CRX submodel is the best candidate 4 a swap
Old 01-28-2004, 08:51 PM   #1
Rep Power: 0 favorJDM is off the scale
Thumbs up
I going to purchase a CRX and I plan to swap a GSR, Type R, or B16 (I have not decided) into the rex but which submodel is the best candidate for the swap. Is it the si, dx, or hf.
favorJDM is offline   Reply With Quote
Old 01-28-2004, 09:30 PM   #2
Rep Power: 51 Slammed90Lude is an unknown quantity at this point
Send a message via AIM to Slammed90Lude
HF is the lightest- But Si is already wired for multi-point injection- the other two are dual point- and i'm not sure you wanna swap in a type r or even a GSR to be honest- OBD 0 to OBD 2 > you
Slammed90Lude is offline   Reply With Quote
Old 01-28-2004, 10:18 PM   #3
jlicrx's Avatar
HF is MPFI - DX is only CRX with DPFI
depends on what you want out of it - 88 HF is the lightest and will be the fastest, although it won't be as nice
ZCspeed Racing
Old 01-28-2004, 10:23 PM   #4
Ride:  06 Chevy Silverado
Rep Power: 88 Jeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud of
Send a message via AIM to Jeef
THE HF IS NOT DUAL POINT, it is MULTIPOINT. The crx dx is the only dual point crx. That does not mean its a bad start, it is not that hard at all to convert to multiport fuel injection. The hubs on the hf will most likely have to be changed out to accomadate larger axles. It is the lightest, but has the least amount of features. The SI has the most features, but it is the heaviest. I can't remember all of the differences, nor do I have time to list them all. Try going to www.crx.org and check out their resource. It should list all of the key differences between the models.
What are the goals for the car? If you are daily driving it, it might pay to get a dx or si with a/c or the si with the sunroof. Just a few things to think about.
Ex 89 crx si,91 & 95 Civic owner.
06 Silverado RCSB 20's, 2/4" Belltech lowering kit, waiting for 2 more cylinders, 1.9 more liters, and 208 more hp engine swap.
Jeef is online now   Reply With Quote
Old 01-28-2004, 10:47 PM   #5
Old 01-28-2004, 11:34 PM   #6
Rep Power: 14 ludegirl is off the scale
Send a message via AIM to ludegirl
Some HFs have a/c and sunroofs
ludegirl is offline   Reply With Quote
Old 01-29-2004, 04:10 AM   #7
Slo86GT's Avatar
Rep Power: 48 Slo86GT is an unknown quantity at this point
Send a message via AIM to Slo86GT Send a message via MSN to Slo86GT Send a message via Yahoo to Slo86GT
NO HF has a sunroof unless it's aftermarket.
A/C was a dealer option on ANY honda in those years. If it wasn't on there from the factory, the dealer could order a kit to install it, so it was available on any model.
HF is the lightest, all of them were 5 speeds, and they have the MPFI wiring already done. They are the best candidate for a swap, but need serious attention to brakes and handling since they don't have sway bars, and the brakes are smaller than the other model to help same some weight.
Si is the next best for swaps, IMHO, jsut because its so easy.
DX's are good cars still, but the wiring, and possibility of it being an auto make it not so great in my mind.
- Jody -
2004 Colorado ZQ8 - I5, M5, Regular cab - 209.9whp/210.7wtq
1986 Mustang GT - V8, M5 - 213.0whp/279.2wtq
Slo86GT is offline   Reply With Quote
Old 01-29-2004, 02:08 PM   #8
Rep Power: 17 CRseX84 is off the scale
Send a message via AIM to CRseX84 Send a message via MSN to CRseX84 Send a message via Yahoo to CRseX84
Post
DX! DX! DX! i am very convinced that DX is the best CRX model to do a swap with. the Si has more luxery options like the sunroof and stuff that are extra weight that are not needed. and sure the Si has all wheel disk and you wouldnt have to change the injector set up but who cares. if you have any skill you can convert the rear drumbs into disks and convert the injector wirring. think bout it if you had a Si you would mostlikely be upgrading the discs anyway so this Dx is prittymuch betr than the Si. also not to mention the Si weight is 2,100 i believe i might be off by a houndred or sumthin but the Dx is 18,000lbs!! as for the HF no offence to those that have one but they kinda require a lil more work to get it up to par. iv HEARD that they suck to do swaps in because they are lacking so much that is needed. so the DX to me is THE best CRX model to do a swap in. B)
CRseX84 is offline   Reply With Quote
Old 01-29-2004, 03:05 PM   #9
Rep Power: 28 Bl6CRX is off the scale
Send a message via AIM to Bl6CRX Send a message via Yahoo to Bl6CRX
no offense bro but you've HEARD wrong...bottom line, its all up to you, avoid dx because of its dual point wiring issues, and if you want some features go with si, also go with si if you looking for more a a road course car, but if you looking for the model that will put down the 1/4 mile best times, HF is it, the only reason i would avoid hf is if your gonna drive it with the stock motor for a good length of time before the swap...basically its what fits your needs
Bl6CRX is offline   Reply With Quote
Old 01-29-2004, 03:07 PM   #10
Rep Power: 19 2fastaccord is off the scale
Send a message via AIM to 2fastaccord Send a message via Yahoo to 2fastaccord
HF or SI. The DX is the last one I would pick. IMHO.
2fastaccord is offline   Reply With Quote
Old 01-30-2004, 02:56 AM   #11
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
DX = have to add two injectors to the system
HF = have to change out the spindles to take the larger axles
You pick... other than that, the swaps between the DX and HF are pretty much the same. The HF is lighter, but like our grammar challenged brethren has stated, it is missing some stuff. The missing items aren't critical at all though.
Old 01-30-2004, 12:37 PM   #12
or use custom axles...personally im a fan of changing out the spindles to 90-91 intergra...it makes life easier...when you need a new axle, go anywhere and get one the the teg...
Old 01-30-2004, 01:43 PM   #13
Calesta's Avatar
Ride:  2003 S2000
True. The Integra spindle has the wrong geometry for the Civic suspension though... the DX or Si spindle is the best choice.
Old 01-30-2004, 02:32 PM   #14
Rep Power: 44 MaaseyRacer is an unknown quantity at this point
Send a message via AIM to MaaseyRacer
anyone who says that the DX should not be used because of its wiring issues should not be attempting to try a swap. converting from DPFI to MPFI is pretty easy and straight forward. Plus with all the resources like this site out there it is hard to phuck it up. My vote is the DX, here is a list why:
No sunroof
Rear windsheild wiper (some people shave them, but I actually use it)
Intermitant windsheild wipers
Light weight, does not have a ton of heavy options
Stylish red bar on hatch
Proper hubs for a b series swap
Better breaks than the HF
Ect. ect. ect.
2004 Toyota Tacoma
3.4L V6
TRD Package
4WD
MaaseyRacer is offline   Reply With Quote
Old 01-31-2004, 10:18 PM   #15
crx
Rep Power: 16 crx is off the scale
i go with what ever i can find in the best condition for the cheapest price. my 2cents
-joseph
Old 02-02-2004, 03:21 PM   #16
Calesta's Avatar
Ride:  2003 S2000
That works too... around here, you don't really have much of a choice on trim models when you're trying to buy CRXs. They just get sold way too quick.
Old 02-26-2004, 12:57 AM   #17
Rep Power: 0 Dj_RiiCe is off the scale
SiSISISISI....man so what if it's a lil weight..if you build up a 200hp whip who cares if u have a lil extra weight...there all amenities any ways..u'll be happy with them......i Love my sunroof !!! special since when i do teh swpa im not buying the AC bracket...the SUnroof is the best for air....
Just my opinion......
Dj_RiiCe is offline   Reply With Quote
Old 02-26-2004, 03:34 AM   #18
Calesta's Avatar
Ride:  2003 S2000
Wow dead thread resurrection...
Contrary to what you might believe, weight matters a LOT, especially in a car that only has 200whp. 200whp isn't all that much.
Old 02-26-2004, 03:53 AM   #19
Rep Power: 12 Tokay is off the scale
True, 200 whp ain't about shit it is however something to start with. Don't let the project overwhelm you, get what ever you want, and then build it up.
Tokay is offline   Reply With Quote
Old 02-28-2004, 05:05 PM   #20
Rep Power: 14 rushcrx is off the scale
Originally posted by SiR Kid+Jan 29 2004, 04:10 AM--><div class='quotetop'>QUOTE(SiR Kid @ Jan 29 2004, 04:10 AM)</div><div class='quotemain'> <!--QuoteBegin-ludegirl@Jan 28 2004, 11:34 PM
[/b][/quote]
ummm yea mine does... and hf is the best candidate PERIOD
QUOTE (HondaMoCo @ Feb 28 2004, 09:42 PM)
these isnt something you tie in with a rope, pop a couple broomsticks in the tranny, wire up the shifter with a coat hanger, rush over to your girlfriends house, and then off to the street races.... then again i could be wrong... give it a shot
rushcrx is offline   Reply With Quote
Old 03-01-2004, 07:31 PM   #21
cheese9988's Avatar
Ride:  2007 Chevrolet Cobalt SS Supercharged
Rep Power: 31 cheese9988 will become famous soon enough
DX wiring is pretty easy, just did it on mine, wire harnesses are easy to find. If you have any electrical know-how you should be able to perform this swap. Just remember to solder and shrink tube connections so that a couple years from now the wire doesn't come apart from corrosion and vibration. Other than the wiring the dx is as straitforward as the SI, and if you want a sunroof, you can always add it.
Is it good when my dipstick is rusty on my jeep?
Linux Mint 6.0
"The only man who makes no mistakes is the man who never does anything. Do not be afraid to make mistakes providing you do not make the same one twice."
Theodore Roosevelt
http://homemodders.com/t188/
cheese9988 is offline   Reply With Quote
Old 03-03-2004, 09:51 AM   #22
dok
Rep Power: 21 dok is off the scale
make your life easy get a si. crxs' don't weight shit
dok is offline   Reply With Quote
Old 03-03-2004, 06:16 PM   #23
Weight does make a difference in light torqueless cars like Honda, plus it will help with handeling. If wieght didn't mean anything then why do a lot of people put a lot of effort into lightening their cars. The dpfi to mpfi conversion is really easy, takes about 2-3 hours at most.
Old 03-03-2004, 07:29 PM   #24
Rep Power: 18 RENR is off the scale
Send a message via AIM to RENR Send a message via Yahoo to RENR
yup a few extra punds are worth it. youll have a sunroof and a better suspension. def worth it IMO
my car is slow but ill kick your ass.
RENR is offline   Reply With Quote
Old 03-03-2004, 09:19 PM   #25
Rep Power: 12 Steve EF Hatch is off the scale
If you talking about swaping a type r into a rex I'd say mpfi swap is the least of your worries!
Holdin on like a hubcap in the fast lane
<a href=\'http://www.totaljdm.com/?id=83310\' target=\'_blank\'>http://www.totaljdm.com/?id=83310</a>
Easy Money
<a href=\'http://hits4pay.com/members/index.cgi?sbeehler\' target=\'_blank\'>http://hits4pay.com/members/index.cgi?sbeehler</a>
Steve EF Hatch is offline   Reply With Quote
H22AdelSol's H22A swap guide. H22AdelSol HYBRID -> BA-BB /CA-CD 14 08-04-2008 09:53 PM
2nd gen Integra Swap Info pissedoffsol Swap Articles 0 01-12-2004 02:16 AM
1st gen Integra Swap Overview (da) pissedoffsol Swap Articles 0 01-12-2004 02:15 AM
Swap Candidate FFCiv HYBRID -> EG-EK / DC 4 03-13-2003 03:57 PM
