d15b2 or b16a?
Old 10-13-2009, 03:18 AM   #1
89 EF Hatch D15B2 w/ 5spd
Zero2sixtyin3's Avatar
Ride:  1989 Honda Civic Hatchback DX
Rep Power: 7 Zero2sixtyin3 is on a distinguished road
Send a message via AIM to Zero2sixtyin3 Send a message via MSN to Zero2sixtyin3 Send a message via Yahoo to Zero2sixtyin3 myspace
Default d15b2 or b16a?
ok well i have the d15b2 in my dx hatch. my question is with basic bolt ons would the d15 be a better choice over getting the full b16 swap? im just thinking on terms of the fact that the d15 is in my car already but im wondering based on cost. i can get a full swap for around 1500 with everything, where as would i have more power if i put 1500 into my current engine?
im leaning towards the b16 but i want some second opinions. thanks for reading.
cant wait to do my B16AT swap .
also if you are looking for any honda performance parts at a decent price let me know and i can price whatever your looking for. Daedalus Motorworks
Zero2sixtyin3 is offline   Reply With Quote
Old 10-14-2009, 11:51 AM   #2
Ride:  1991 Honda Civic Si Hatch
Rep Power: 1 ZCpowerdSI is on a distinguished road
Get rid of the d15b2. no good. B16 it. even if you boosted the d15 you cant make as much power as a b16 unless you build the engine. they have like 70whp, and boosting it and building it would cost more than the full b16 swap. you can get a full b16a swap for around $1500-$1800
ZCpowerdSI is offline   Reply With Quote
Old 10-14-2009, 12:04 PM   #3
Ride:  1991 civic hatch dx
Rep Power: 5 Bobby17772 will become famous soon enough
actually they have about 90! haha. Personally I would go LS but that's just me, you can find them a lot cheaper and more common. but you will have to convert it over to mpfi before you do any swap.
It is possible to see numbers out of the D15b2, you could probably get it to about 200-220 hp for 1500, mini me swap, port and polish, turbo, basic bolt ons, and an amazing tune. of course you could do more but thats just basics.
The B16 depending on what model you get it has about 150 hp, for that you may have to convert it over to obd1 (correct me if I'm wrong) model depending. for that you would have to get the different motor mounts, axles, ecu, harness, and trans...if you're not already getting that with the swap. But this would probably be the more reliable choice seeing that it's got 50% more power and it's still stock.
Or for even cheaper you could but a DOHC ZC engine and it's a direct swap and they are pretty good engines for d-series.
It may sound stupid but when it comes to engines you can't go wrong when it comes to building..if you think a head at least. if you build it and it breaks, rebuild it, if you can't rebuild it, swap it to something better.
Bobby17772 is online now   Reply With Quote
Old 10-14-2009, 12:19 PM   #4
yes. i recomend the dohc zc. thats what i have and it goes good with a light weight crank pulley, ported and polished head, pace setter header, and a cold air intake.
Old 10-15-2009, 12:15 AM   #5
well i do know that the b16a aka b16a1 is a direct swap if i get the one from the 88-91 model jdm sir civic. and it has 160hp and i think around 110 torque. i am thinking that might be the best way to go (with the b16) i want to do the jdm front end so basically my car would be what japan had but alot faster after i turbo it and lhd. anyone know of the best cams to get when it comes to boosting the b16, going to do a t3/t4 hybrid most likely. still wanting streetable performance, not planning on anything more than 350whp but then again im not totally sure what kind of numbers the b16 can put out being built and boosted. i am going to do internals though since it will be my DD.
Old 10-15-2009, 01:08 AM   #6
dtob's Avatar
Rep Power: 11 dtob is an unknown quantity at this point
Stock cams would work fine, an upgrade isn't necessary but GSR cams or ITR cams would be a good upgrade and cheaper than the aftermarket counterparts.
dtob is offline   Reply With Quote
Old 10-15-2009, 10:31 AM   #7
oh yeah, i wathinkin about the d15b1 its about 70ish, and the d15b2 is about 92hp
Old 10-15-2009, 10:59 AM   #8
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
Rep Power: 214 INJEN78 has a reputation beyond repute
INJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond repute
if i was you id swap an ls in it and boost the ls...like bobby said.
R.I.P BEN LEE2/24/08 we love and miss you
http://burnoutbox.activeboard.com/in...BID=127652&p=1
GOOD FAST CHEAP,
you can pick only two.
fast and cheap isn't good
good and cheap isn't fast
good and fast isn't cheap
Old 10-18-2009, 04:44 AM   #9
so hat is so amazing about an ls swap exactly? aside from the fact that its more time consuming due to wiring conversion and such? gotta remember its a dd for me so i cant have it down for too long with wiring and i dont exactly have my money tree in full bloom around this time of the year. the leaves tend to start falling around this time
Old 10-18-2009, 10:45 AM   #10
because the b18 series has a ton of potnetial, thats why I can't wait to get mine. I'm not knocking the d16a in anyway because that's a great engine as well but if you were going to swap in a b16a then you would already have the mounts for an ls and it would be a lot cheaper. If you talk to a guy on here, I think his name it monotech...something like that. he can make you a harness, and if you wanted to run it obd0 you could, all you would need to get is just the obd0 dizzy, and the right ecu. and you could probably do it cheaper then the b16a but it really just comes down on what you want to do
Old 10-18-2009, 01:06 PM   #11
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
because the LS would be the same wiring as the b16a..you would still have to convert to mpfi and possibly obd1..and the LS is the next easiest thing than swapping your existing motor..and then later when you have ,oney and want power there is a slew of parts
GOOD FAST CHEAP,
Old 10-18-2009, 05:29 PM   #12
The name's Sam
philyphreak2127's Avatar
Ride:  98 civic dx sedan, 80 trans am
Rep Power: 26 philyphreak2127 is a jewel in the roughphilyphreak2127 is a jewel in the roughphilyphreak2127 is a jewel in the roughphilyphreak2127 is a jewel in the rough
if you wanna keep the b2 a cheap way to add a good amount of power would be to find a z6 head, y8 intake manifold w/ injectors, a cai, full exhaust. run the p28 ecu and have it tuned. you can with the right parts put down almost 150 horses believe it or not. If you wanna go further you could add a cam, port the head, adjustable cam gear to advance timing a bit, lightweight crank pulley, and lightweight flywheel.
philyphreak2127 is offline   Reply With Quote
Old 10-18-2009, 08:46 PM   #13
Christmas Car
Ride:  93 4dr D15B, Greddy Short Ram, 4-2-1 Header, 2.5" Exhaust.
Rep Power: 8 RoughKnight has a spectacular aura aboutRoughKnight has a spectacular aura aboutRoughKnight has a spectacular aura about
^I'm living that statement (almost)
Please direct your questions in the following format.
1) Did I search it on Google?
2) Did I use the search function in the TOP RIGHT AREA of this page?
3) Refer to Step 1 and 2.
If that doesn't work, then feel free to post.
RoughKnight is offline   Reply With Quote
Old 11-06-2009, 11:58 PM   #14
ok so for now i am going to build a d15b1 i picked up for a hell of a deal. like 60 bucks kind of deal lol. it has everything but the intake & exhaust manifolds, and dizzy. i want to check my local junkyards an upulls first before i check ebay and CL and the forums. i have a few shops in the area that i can go to for tuning and alot are offering decent prices too and that includes dyno when i get to that point.
lets make these questions into a list to make it simpler.
am i going to need an obd0 to obd1 jumper?
what does the z6 head come in factory? what about the y8 intake mani?
should i go with an aftermarket header and for what model or motor so i can find one?
is mpfi required and/or recommended with the swap? anyone or site that has the dpfi-mpfi harness already done?
can i use my stock dizzy?
what cam should i run? like brand and stage?
where is the best place to find the cam gear, crank pulley, and a good clutch kit w/ light flywheel? i plan to get the head ported and such when i find it.
and lastly is there anything else i could do to get a bit more power out of this motor aside from turbo? but without going high compression because a turbo is an option later on.
Tags
b16a, b16a sir, b16a swap, bolt ons, d15b
D15B2 to B16A Wiring - Which Wires? geoff-r HYBRID -> EG-EK / DC 0 06-16-2008 07:04 PM
JDM B16A into 92 Civic LSi (D15B2) geoff-r HYBRID -> EG-EK / DC 3 03-19-2008 02:51 PM
Need some help with a D15B2, please... jgrant HYBRID -> ED-EF / DA 4 12-25-2006 11:15 PM
D15B2 Magik General Tech and Maintenance 6 12-05-2003 02:37 PM
D15b2 ilovebrittany HYBRID -> EG-EK / DC 1 02-25-2003 06:45 AM
