Ok, so my friend has a 91 hatch. It was originally obd0 obviously but it was swapped to obd1. However, they left the dpfi on it being morons and now want to go b18a1 obd1 for serious tuning purposes. My question is since the car is technically obd1, what needs done wiring wise to swap a b18a1 into it. Someone said a b series obd1 harness will do it but I don't see how. It can't be that easy.
i think it was rewired cause it was a cut harness and resoldered so it is wired in as obd1 but never converted. it has a d15b7 in it with obd1 ecu and all. thats why i am lost as well cause he wants to do a b18a1 swap into it and i have no clue where to start. i see all these swaps and everyone goes obd0 cause it is easy but we are building it to boost and cant boost a obd0.
Ride: 1991 civic hatch dx
well first would be to convert it over to mpfi. There is a great write up on here if you want to do it yourself, or there is a guy on here there sells different harnesses and I'm if you don't see one he can make you one, the price is pretty cheap and he doesn't require a core charge so he's a good idea
#6 |
Harness conversions obd-0 obd-1 v-tec ecus & parts I believe it's the 5th one down that you need. if not like I said you can just contact him, he's very easy to work with
#7 |
ok, well, i bought an extra harness from pick n pull today so i can do the obd0 dpfi - mpfi myself but i was wondering is there a place to find a d-i-y for obd0-1 jumper or wire it myself? i went though college for hardware wiring so it doesnt seem like it will be too hard to do either just need to know materials. thanks for all this help man.
#8 |
¿GANGSTA GREMLIN?
Ride: 91 CRX si
you cant convert to obd1 without also going mpfi..there is no dpfi obd1 motor
R.I.P BEN LEE2/24/08 we love and miss you http://burnoutbox.activeboard.com/in...BID=127652&p=1 GOOD FAST CHEAP, you can pick only two. fast and cheap isn't good good and cheap isn't fast good and fast isn't cheap |
#9 |
precisely. your ecu is obd0. to run the ls just convert to mpfi and get yourself an obd0 pr4
91 Civic Si b18b1, I/H/E, 6000k HID kit, 94 teg cluster Parting mustang out to buy another civic
#11 |
¿GANGSTA GREMLIN?
Ride: 91 CRX si
so make your own..im sure you could find someone with a jumper that you could get an idea of what you need to do..
but there is no way your harness was made into obd1 without doing the mpfi as well..so first y ou need to figure out what is going on with that __________________
#13 |
Ok, I guess I'm going to go dpfi to mpfi then look into someone's harness for a pinout and do that. The car has 2 ecus but one is used so I will pull the other apart and use it as a start. Any ideas as fat as where to find a pinout? Local guys do t run boost to crx/ef civics so I'll be the first there but that also means I gotta do it ony own. Thanks for the advice so far though guys.
#14 |
¿GANGSTA GREMLIN?
Ride: 91 CRX si
and the d15b7 is also obd1 so i rlly dont know what is going on with your car..
#17 |
¿GANGSTA GREMLIN?
Ride: 91 CRX si
exactly..check the code on the engine..and take pix of the bay...is there a resistor box on the drivers shock tower?
#21 |
¿GANGSTA GREMLIN?
Ride: 91 CRX si
lol yep..so its obd0 dpfi
#22 |
not necessarily. it might still be a d15b7. previous owners might have just swapped over the b2 dizzy and dpfi manifold to the b7.
#24 |
¿GANGSTA GREMLIN?
Ride: 91 CRX si
most likely kept the b2...just check the block for the code...
#25 |
block says b7. i think thats why i dont trust the guy on anything. he said it was swapped, only thing different is the block. its still pretty much a d15b7. anyways, so back to step 1. i am preparing to do a dpfi to mpfi conversion, after that how do i setup for a b series swap? non vtec. obd1 for tuning purposes.
| d15b2-d15b7 swap confusion | EFDX | HYBRID -> ED-EF / DA | 9 | 01-28-2009 11:57 PM |
| d15b7 from d15b2 | thegreat1310 | HYBRID -> ED-EF / DA | 4 | 01-28-2009 11:51 AM |
| D15B7 head on a D15B2 will it work? | tepco | Civic and CRX - EF | 6 | 01-30-2008 07:30 PM |
| D15B7 head on a D15B2 will it work? | tepco | Civic and CRX - EF | 0 | 01-30-2008 12:04 PM |
| 89 D15B2 block and head into 92 D15B7.. | m735is | HYBRID -> EG-EK / DC | 3 | 04-06-2004 07:51 AM |
