d15b7 from d15b2
Old 11-13-2005, 11:14 PM   #1
thegreat1310 is off the scale
Send a message via AIM to thegreat1310
i recently drop a d15b7 in my 91 civic hatch.the car was a dual point setup, so i converted it to the mpfi, but know i have a problem starting it! it catches at first than dies, anybody know what the problem could be?if i spray starting fluid in the throtlle body it kicks and stays running on its own just needs a quick spray to get going. any thoughts could help thanks for reading or replying!!! [img]style_emoticons/<#EMO_DIR#>/ph34r.gif[/img]
thegreat1310 is offline   Reply With Quote
Old 11-14-2005, 12:00 AM   #2
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Calesta has a reputation beyond repute
Calesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond repute
Firing order?
Old 11-15-2005, 02:02 AM   #3
no the firing order is right i think it could be the crank angle sensor
Old 01-28-2009, 10:15 AM   #4
megabyte is on a distinguished road
Are you getting a crank angle code? You might be. If you do then check your wiring. And your pin out. Ive done 3 off these swaps and on of them some one had already messed with the stock wiring harness. So check a stock harness pin out and a si wiring pin out and compair the 2. I had to take all the pins out of my last one and start over.
megabyte is offline   Reply With Quote
Old 01-28-2009, 10:51 AM   #5
^^ Likes Bewbies
George777's Avatar
Ride:  Rex, Yamaha Virago, CB900F Supersport
George777 has a reputation beyond reputeGeorge777 has a reputation beyond repute
George777 has a reputation beyond reputeGeorge777 has a reputation beyond reputeGeorge777 has a reputation beyond reputeGeorge777 has a reputation beyond reputeGeorge777 has a reputation beyond reputeGeorge777 has a reputation beyond repute
Three years later, I certainly hope he got the problem fixed.
Check the dates on the thread, noob.
George777 is offline   Reply With Quote
