d16 to b16 engine harness question
Old 01-28-2008, 03:23 AM   #1
scottie fizzle
HATCHET_HONDA's Avatar
Ride:  90 civic si hatch, 91civic dx hatch
Rep Power: 17 HATCHET_HONDA has a spectacular aura aboutHATCHET_HONDA has a spectacular aura aboutHATCHET_HONDA has a spectacular aura about
Send a message via AIM to HATCHET_HONDA myspace
Default d16 to b16 engine harness question
so im swappin a b16a into my 90 dx hatch. my question is what engine harness do i need? can i use the dx harness and wire in the extra sensors? or will the b16 harness plug into the main plugs just like the d16?
admit it..your a ricer....
90 si hatch jdm d15b swap(done)
91 dx hatch b16 swap (in progress)
b16a block
95 gsr p&p head
skunk 2 valvetrain
stage 1 cams
type r bottom end
tri y header
stage 3 act clutch ftw
HATCHET_HONDA is offline   Reply With Quote
Old 01-28-2008, 09:59 AM   #2
Domi31's Avatar
Rep Power: 12 Domi31 is on a distinguished road
Rywire - Online Store ftw
-92 civic w/ 97 B18C-R I/H/E traction bar
13.893@ 98.52mph
-95 LS Integra I/H Beater car (Rear ended RIP)
15.62@ 86.27
-00 Civic Si I (my DD)
b16 SiR-II swap
Domi31 is offline   Reply With Quote
Old 01-28-2008, 03:10 PM   #3
scottie fizzle
if i got a 91 si harness(or another mpfi harness from the same year).. would that make the dpfi to mpfi process easier? i figured since the extra injector plugs are already there... ive done the mpfi swap before so i know it can me a PINA
b16a block
95 gsr p&p head
skunk 2 valvetrain
stage 1 cams
type r bottom end
tri y header
Old 01-28-2008, 11:56 PM   #4
scottie fizzle
cool..ill stick with the dx harness then. ive done it once already, i kinda remember how everything goes. gotta love them how to forums
b16a block
95 gsr p&p head
skunk 2 valvetrain
stage 1 cams
type r bottom end
tri y header
Old 01-29-2008, 12:11 AM   #5
I'll be back...
B16RacerN2NR's Avatar
Ride:  06 Mazda 5, 91 Civic DX
Rep Power: 156 B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
Send a message via AIM to B16RacerN2NR myspace
Originally Posted by Blanco View Post
They're wired differently. It's really not hard to make the changes.
Just to touch on this some more... aside from being wired a little different, the shock tower plugs are different sizes as well. You'll never get it to plug in.
I will be moving to Avondale, AZ in June for 6 months to finish school. Hit me up if you're close to that area so we can chill...
B16RacerN2NR is offline   Reply With Quote
Old 01-29-2008, 12:18 AM   #6
scottie fizzle
got any tips on how to remove that last bolt on the rear trans mount? i wanna start flattening the lip down
b16a block
95 gsr p&p head
skunk 2 valvetrain
stage 1 cams
type r bottom end
tri y header
Old 01-29-2008, 12:53 AM   #7
scottie fizzle
i cant even reach it....does the damn rear crossmember need to come down?
b16a block
95 gsr p&p head
skunk 2 valvetrain
stage 1 cams
type r bottom end
tri y header
Old 01-29-2008, 01:19 PM   #8
scottie fizzle
the frame...i tryin to get the rear bracket thats mounted on the crossmember
b16a block
95 gsr p&p head
skunk 2 valvetrain
stage 1 cams
type r bottom end
tri y header
engine theories(ignition) INJEN78 Members' Lounge 9 12-20-2007 11:00 PM
88-91 Honda CRX Civic Si MPFI engine wiring harness D16 RSS-Bot Auctions 0 12-12-2007 10:33 PM
Integra civic ex wiring harness engine b swap vtec b16 RSS-Bot Auctions 0 11-19-2007 04:03 PM
zc swap into 85 crx? devnjeff HYBRID -> ED-EF / DA 4 07-10-2005 11:09 PM
Engine harness question! Danli HYBRID -> EG-EK / DC 5 12-15-2003 02:04 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
