d16 compression problems? Yikes
Old 10-31-2009, 12:25 AM   #1
Greenhorn
Rep Power: 0 k20chicano is on a distinguished road
Default d16 compression problems? Yikes
hello, I needed to know what is normal compression for a d16a6 si? I checked my comp and its 110-75-150-112. Is that normal. I think this is why my car stalled and now wont start. I have spark, fuel, and air.
k20chicano is offline   Reply With Quote
Old 10-31-2009, 02:03 AM   #2
D16SiHatch's Avatar
Rep Power: 33 D16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud of
no thats definitely not normal. it's actually quite terrible. mininum psi spec for an a6 is 135psi and nominal is 185 psi, with a max variation between cylinders of 28 psi. so basically your engine's rings are fried.
91 Civic Si
b18b1, I/H/E, 6000k HID kit, 94 teg cluster
Parting mustang out to buy another civic
D16SiHatch is offline   Reply With Quote
Old 10-31-2009, 08:35 AM   #3
Ride:  99 ex, d16y8 PnP, headers, exhaust, crower cam, 135whp
Rep Power: 4 josh_crewdson@y is on a distinguished road
or your head gasket is leaking, did it smoke before all this?
josh_crewdson@y is offline   Reply With Quote
Old 10-31-2009, 11:20 AM   #4
¿GANGSTA GREMLIN?
INJEN78's Avatar
Ride:  91 CRX si
Rep Power: 214 INJEN78 has a reputation beyond repute
INJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond reputeINJEN78 has a reputation beyond repute
leakdown test time
R.I.P BEN LEE2/24/08 we love and miss you
http://burnoutbox.activeboard.com/in...BID=127652&p=1
GOOD FAST CHEAP,
you can pick only two.
fast and cheap isn't good
good and cheap isn't fast
good and fast isn't cheap
Old 11-02-2009, 01:51 PM   #5
Ride:  90 crx w/zc dohc
Rep Power: 8 Fernpatch has a spectacular aura aboutFernpatch has a spectacular aura aboutFernpatch has a spectacular aura about
myspace
Try a wet compression test. Remove the spark plugs, pour a little ATF down each hole. Hook up a battery charger. Open the throttle wide open. Crank and see what you read. I have seen many hondas lose there ring seal from sitting around too long. Also check your cam timing, If you jumped a few teeth you could have all kinds of screwed compression readings. Can you provide a little more information on what happened when it died?
What I write is my own opinion based on what I have done. Your own results may vary...
"Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, torque is how far you take the wall with you." --Anonymous
Fernpatch is offline   Reply With Quote
problems with high compression swap... possibly tuning? dustyb20 General Tech and Maintenance 13 11-17-2008 03:17 AM
LS/VTEC Compression Yikes! EKJOE Engine Building 3 11-09-2008 09:18 PM
Problems after compression test Psyco609 HYBRID -> EG-EK / DC 3 09-01-2005 10:16 PM
YIKEs!! Captinb16 ECU's, Electronics, and Tuning 8 12-23-2003 11:02 PM
mini me compression problems? cointelpro Engine Building 1 10-20-2003 04:41 PM
