D16A6 - D16Y8 Mini Me Swap
Old 07-26-2004, 10:45 PM   #1
Rep Power: 11 Projekt Koncept is off the scale
My friend owns a 1990 Honda CRX Si, and wants to do a Mini Me Head Swap. He's looking to swap out the A6 head with a Y8, as it offers higher compression than a Z6. My question is, where can he find a complete head other than a junkyard? I've been searching google to no success. And ebay doesn't look to promising. Also, is there anything besides the head he would need? Any suggestions and help would be appreciated.
Projekt Koncept is offline   Reply With Quote
Old 07-26-2004, 11:56 PM   #2
Rep Power: 13 dreded90crxsi is off the scale
Send a message via Yahoo to dreded90crxsi
About the only place you'll find a y8 head is through a junk yard, ebay, or people selling them through internet forums. I would try checking every honda related forum you can find and look in their for sale sections. Things you will need besides the head is wiring up vtec and finding a way to activate it. The best way to do it is to convert from obd0 to obd1 and run a p28 ecu. It will give you better fuel maps and has vtec activation already in it. Another good idea is to get the y8 intake manifold. It flows air much better then the a6. Oh yeah when converting to obd1 you will have to change the fuel injectors and distributor.
Life is a race, what place are you in?
dreded90crxsi is offline   Reply With Quote
Old 07-27-2004, 12:45 AM   #3
Ride:  1989 Honda CRX HF
Rep Power: 28 MugenCRX is an unknown quantity at this point
Send a message via AIM to MugenCRX
You will also need a new headgasket, I would recommend ARP headstuds if your friend plans on doing anything in the forced induction department and look into converting to OBD1. It will save your friend some headaches.
They say that you only live life once, but if you live like me....once is enough!
-Frank Sinatra
MugenCRX is offline   Reply With Quote
Old 07-27-2004, 01:03 AM   #4
Thanx guys, that answered the most important question, on where to get a Y8 Head. After Swaping the head, I'm assuming he'll get some aftermarket Cams and then a Turbo. So with all of this in mind, what is needed to convert from OBD0 to OBD1? And do you have any other suggestions?
Old 07-27-2004, 01:29 AM   #5
To convert from obd0 to obd1 you can either buy a conversion harness from hasport or you can do the wiring yourself. If you do a search on google for obd0 to obd1 conversion you should be able to find plenty of sites that will tell you step by step how to do it.
Old 07-27-2004, 09:41 AM   #6
Would this be the correct wiring harness, to convert to OBD0 to OBD1?
http://hasport.com/shop/product_info.php?products_id=85
Old 07-27-2004, 09:51 AM   #7
Not sure if that's the one or if thats just to wire up everything from the b16 such as vtec. These will work though.
http://www.boomslang.us/obd0.htm
http://jkobdconversionharness.com/mpc/docs...0to%20OBD1.html
Old 07-28-2004, 12:24 AM   #8
So far this is the list of things my friend will need for the Mini Me swap. Hopefully I haven't missed anything.
OBD0 - OBD1 Wiring Harness
p28 ECU
Fuel Injectors
Distributor
Headgasket
And of course, the Y8 Hhead.
About the ECU, would this be aquired from Hondata, or is it a stock ECU from a newer model? Sorry if this sounds n00bish, but this is somewhat of a learning curve for us. :sad: But we are learning! Much thanx again!
Old 07-28-2004, 03:35 PM   #9
The p28 is a stock ecu from 92-95 civic ex and si.
Old 10-20-2008, 07:11 PM   #10
d16a6/d16y8 "mini-me"
89' Project Civic's Avatar
Ride:  1990 Honda Civic Si
Rep Power: 22 89' Project Civic is a glorious beacon of light89' Project Civic is a glorious beacon of light89' Project Civic is a glorious beacon of light89' Project Civic is a glorious beacon of light
Send a message via MSN to 89' Project Civic
Sorry to open up an old thread guys, but I'm doing a mini-me swap (d16a6 bottom end, d16y8 top end) as well and was just wondering when you said about doing a obd0 - obd1 conversion, wouldnt it be either a obd0 - obd2a or 2b?. I have a p28 ecu for my mini-me swap. I'm just a noob as well and dont know much and am rather confused so I'm not challenging anyone I just need to know what to do, thanks guys!!. As well, I have the y8 head COMPLETELY apart and it's going for a hot-tanking soon, Im looking to maybe go Stage 2 or 3, which companies should I use and would this be a bad idea??.
89' Project Civic is online now   Reply With Quote
Old 10-20-2008, 07:41 PM   #11
HNFTuning
D15Beater's Avatar
Ride:  or die....
Rep Power: 19 D15Beater is a glorious beacon of lightD15Beater is a glorious beacon of lightD15Beater is a glorious beacon of lightD15Beater is a glorious beacon of light
Send a message via Yahoo to D15Beater myspace
You could just run a pw0 or pr3 on that. Theyre both obd0 and you would only have to run the vtec wires and knock if you went with the PW0. Its a dohc ecu but the y8 head will put you around the same C/R as the B16. Use a y8 head gasket, if you shave the head i wouldnt go over 0.010 of a inch. that would put you around the 10.5:1 ratio.
D15Beater is offline   Reply With Quote
Old 10-20-2008, 07:51 PM   #12
I already bought the p28 for $40 on eBay.ca. So, what your kind of saying is that if I just do a fresh stock rebuild and shave the head by 0.010 of a inch I will get 10.5:1 cr?. I am kind of confused if I'm staying with a d-series so I don't know if it's worth building the engine really hardcore, do you think sticking with a stage 3 d16y8 would be worth the money and time or will I just build this mini me stock then want a b16a2?. Also, I don't NEED to go with a obd2 setup? Thanks alot for the reply!!.
Old 01-11-2009, 03:54 PM   #13
SOHC Fury
wes lee's Avatar
Ride:  91 civic si hatch
Rep Power: 5 wes lee will become famous soon enoughwes lee will become famous soon enough
i thought all we had to do was run a P28 and convert to OBD1 (even though the Y8 is OBD2) i know that OBD1 is able to convert to OBD2 so there shouldnt be an issue
you eat pieces of shit for breakfast!?
wes lee is offline   Reply With Quote
Old 01-11-2009, 04:12 PM   #14
yeah, it's a vtec.
c-rex-beat's Avatar
Ride:  89 crx/z6
Rep Power: 4 c-rex-beat is on a distinguished road
myspace
on my swap I used a p28, jumper harness, use a6 fuel rail and injector and intake manifold just to maki it easy. if you use the y8 injector you will also need to change the conetors on harness and the fi box in the corner for it to work and get the same result. use gasket for y8 and get arp head studs for the a6 block. once you raise the compression you will not be able to boost with out blowin the f up. I do have a y8 head minus the vtec solenoid, fresh cam and valves, powder coat cover (orange). pm me if interested.
c-rex-beat is offline   Reply With Quote
Old 01-11-2009, 10:17 PM   #15
SOHC Fury
wes lee's Avatar
God i can't wait to blow mine the fuck up!!!
Old 01-11-2009, 10:24 PM   #16
SOHC Fury
wes lee's Avatar
Thumbs up
thanks for that info!!! saved my ass
Old 01-12-2009, 12:42 PM   #17
He's 100% right, how's the swap coming along wes lee?
Old 01-12-2009, 05:19 PM   #18
Ride:  91ciivic 95 Legend 92 Legend(KA7s) 87 TBird 5.0HO Map converted, 71 429 TBird ThunderJet
Rep Power: 3 Reboticon is on a distinguished road
You can't hot tank aluminum.
Only place on the net with wiring for B18a1/Auto swap.
http://hondaswap.com/hybrid-ed-ef-da...ng-how-189325/
Reboticon is offline   Reply With Quote
Old 01-13-2009, 02:09 PM   #19
huh?
Old 01-13-2009, 02:09 PM   #20
I know you can't, but who said that?
Old 01-16-2009, 01:32 PM   #21
Rep Power: 5 raceinspiredrex is on a distinguished road
i've heard people saying you can put your head and parts in the dishwasher. like a low budget hot tank lol. what's anybody know about that? good? bad? let me know as it doesn't sound like too bad of an idea
raceinspiredrex is offline   Reply With Quote
Old 01-16-2009, 10:46 PM   #22
Yeah man, I don't know if I told you that one yesturday, but I'd suggest it. I just got my laundry tub water STEAMING HOT with soap and scrubbed it, I also used pipecleaners to detail it, then I blew it out with my air hose. I also repeated it like 3-4times and it was as good as new. There will be new pics of it in my thread on Monday.
Old 01-17-2009, 10:33 AM   #23
i've already had my head partially cleaned at the machine shop, i didn't have it completely tore down so it didn't clean some small areas. anyways, yeah, when my girlfriend's not at home i'm going to soak all of my parts and then i'll throw them in the dishwasher lol
Old 01-17-2009, 12:13 PM   #24
HeHe, good idea man, what isn't off of it?.
Old 01-17-2009, 03:31 PM   #25
well when i had it cleaned before to have it checked for cracks, i didn't pull the valves out. so once i did that, there was a bunch of crap between the valve springs and retainers. also, the bottom retainer, there was a bunch of crap between that and the seat. and i'm going to soak my valves for awhile and then run them through because there's carbon deposits caked on it. i'm going to run my springs and retainers through too
