d16y8 in 1990 dx facts
Old 01-20-2009, 09:37 PM   #1
Greenhorn
Rep Power: 0 05Evo8 is on a distinguished road
Default d16y8 in 1990 dx facts
Hi, My names Brandon I've got a 1990 Honda Civic Dx HB and I've come across a good deal, a 1999 Civic Ex 5 speed coupe with 140k that's been totaled for $200. I'd like to swap the motor into my car but I'm wondering what's the easiest and cheapest way to wire the two together... I have no intentions of upgrading the motor or ecu, just want some extra passing power. Any information about the swap would be greatly appreciated.
05Evo8 is offline   Reply With Quote
Old 01-20-2009, 09:48 PM   #2
D16SiHatch's Avatar
Rep Power: 33 D16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud of
do you own an evo 8. if so your a bastard. give it to me lol.
now onto your problem. if you want it to run decent and actually give you more passing power you're going to need an ecu with fuel trims that work well with that engine. trying to run it with the stock pm6 non-vtec ecu would be a bad idea. converting to obd2b would be a pain in the dick so your best bet would be to get a d16z6 ecu (p28) and convert your car with an obd0-obd1 jumper and subharness.
since your car is a dx you'll also have to convert the fugger from dpfi to mpfi. and unfortunately there is no easy way to get around this.
DPFI to MPFI writeup
and then you'll need the jumper itself
Rywire - Online Store
91 Civic Si
b18b1, I/H/E, 6000k HID kit, 94 teg cluster
Parting mustang out to buy another civic
D16SiHatch is offline   Reply With Quote
Old 01-20-2009, 10:10 PM   #3
Greenhorn
Yes I have the evo as a summer car and picked up the honda as a winter beater... How much do you think this type of swap would cost considering I would have a complete car to strip parts from?
Old 01-20-2009, 10:59 PM   #4
D16SiHatch's Avatar
are you doing the swap yourself? if not, you'll have to see who could do this for you, and what it would cost.
otherwise your looking at the price of the jumper harness and the p28 ecu. thats about it. its pretty much a direct swap. use the mounts off the a6 on the y8, and drop her in. fuel lines, shift linkages, wiring, you'll use everything from the dx.
91 Civic Si
Old 01-25-2009, 06:39 PM   #5
Rep Power: 2 boostfreak 417 is on a distinguished road
so is the jumper and wiring it to mpfi all thats needed
boostfreak 417 is offline   Reply With Quote
1990 Civic Cx d16a6/d16y8 engine build 89' Project Civic Civic and CRX - EF 19 03-18-2009 07:24 PM
d16y8 into 1990 dx chassis? fat honda kid Civic and CRX - EF 1 10-11-2008 06:55 PM
21 interesting facts:) jdmthathoeee. Members' Lounge 54 05-29-2008 08:48 PM
1990 Civic DX HB /w D16Y8 NA - Power Swap Jon_S13EF HYBRID -> ED-EF / DA 16 05-24-2006 08:43 PM
facts of death pissedoffsol Members' Lounge 12 05-23-2004 11:44 PM
