D16y8 crx swap
Old 08-03-2007, 02:28 AM   #1
Rep Power: 0 edgar89crx is on a distinguished road
Default D16y8 crx swap
Hello i need some help with a motor swap im doing. To start off i have a d16y8 motor that i wanna put in an 89 crx hf. I just needed help on what ohter parts im gonna need for the swap and so far i have these parts. Thanks
d16y8 with an 89 crx si tranny bolted up
ob0 to 0b1 conversion harness
p28 ecu
obd-1 dizzy
edgar89crx is offline   Reply With Quote
Old 08-03-2007, 03:01 AM   #2
jlicrx's Avatar
you will need aftermarket mount kit (like Hasport) and shift linkage - you will need to use the HF engine wiring harness and do the wiring changes to it
ZCspeed Racing
Old 08-03-2007, 01:14 PM   #3
But as far injectors can i use the ones on the d16 motor or will i have to use the ones off the crx hf. Also since im converting it to obd1 i was told i needed an obd-1 distributer is this true?
Old 08-03-2007, 03:22 PM   #4
jlicrx's Avatar
you can use the D16Y8 injectors - you just need to remove the injector resistor box from the system - you will need OBD1 distributor
ZCspeed Racing
Old 08-03-2007, 04:03 PM   #5
Thanks also one more thing the obd-0 to obd-1 one harness that i have doesnt have the extra wires for the 4-wire o2 sensor. Is it possible to run the car with out the 4-wire o2 sensor.
Old 08-04-2007, 02:32 AM   #6
jlicrx's Avatar
not without getting a check engine light for O2
ZCspeed Racing
Old 08-04-2007, 08:51 AM   #7
übber ɐɾuıu etarip
Z6CRX's Avatar
Ride:  1995 BMW 318ti, 1985 Honda VF500F(now legal)
Rep Power: 73 Z6CRX has a reputation beyond repute
Z6CRX has a reputation beyond reputeZ6CRX has a reputation beyond reputeZ6CRX has a reputation beyond reputeZ6CRX has a reputation beyond reputeZ6CRX has a reputation beyond repute
Send a message via AIM to Z6CRX Send a message via Yahoo to Z6CRX myspace  FaceBook
I dont think u need aftermarket mounts and shift linkage
They are using the cable tranny so shift linkage and mounts should be the same, as long as the driver mount and bracket is moved from the old motor.
As for the O2 I dont remember what position's the wires go to the ECU but there is an O2 heater and an O2 heater sensor. The O2 heater needs the same voltage power source the injectors have.
Originally Posted by Celerity View Post
No one hates anyone around here more than people hate Celerity. He's an asshole.
Z6CRX is offline   Reply With Quote
Old 08-04-2007, 11:48 AM   #8
jlicrx's Avatar
you are correct - i thought he was doing a B-series - got it mixed up with different thread
ZCspeed Racing
Old 09-11-2009, 10:45 PM   #9
Ride:  89 CRX
Rep Power: 1 shadycrx89 is on a distinguished road
nice write up . but im also doing a y8 swap
i want to know if i can keep it obd-0 and what parts i must remover from my y8 engine to keep it obd-0
shadycrx89 is offline   Reply With Quote
Old 09-12-2009, 02:02 AM   #10
Rep Power: 4 craftymatt is on a distinguished road
When I swapped a b16 into my CRX I totally overlooked the fact that I had high impedance injectors (it was an OBD1 B16 running OBD0 electronics) and a resistor box. Car actually ran fine except idle sucked, I guess 02 correction was enough to make it run okay. I felt really stupid when I finally figured that out
Anyway, I don't think there's really anything that needs to be removed on the y8, just need a hacked OBD0 ecu to activate VTEC right?
craftymatt is offline   Reply With Quote
Old 09-12-2009, 11:03 AM   #11
Ride:  89 CRX
yea but the engine is obd2 so will i have to use the obd2 harness or use ond-0 harness on the y8 when i swap it to crx
WTB: D16Y8 Swap Travis3265 Parts: For Sale/Trade/Wanted 5 11-12-2003 10:05 PM
90 civic hatch swap either d16y8 or d17a2 volcomef9 HYBRID -> ED-EF / DA 2 10-09-2003 02:01 PM
Swap D16Y8 -> B18C5 CoupeLG HYBRID -> EG-EK / DC 1 10-05-2003 05:15 PM
D16y8 Swap freshclive HYBRID -> EG-EK / DC 4 04-18-2003 05:41 PM
Swap D16y7 For D16y8 D See 2 ECU's, Electronics, and Tuning 0 01-13-2003 12:00 PM
