Ride: 89 CRX Si <br>91 Hatch Si (& a few other trucks and classics that don't exactly apply to this forum)
I've been told I can back-date an OBD1 distributor to run on an OBD0 ECU. what's involved? do I simply re-pin the connector to fit my wire harness?
I have an extra PR3 ecu from my other project, I was going to chip it and run some stock D16Z6 maps and back date the distributor. Should I run a 1wire o2 or can I run a more accurate 4 wire? |
¿GANGSTA GREMLIN?
Ride: 91 CRX si
ive never heard of this,why not just get an obd1 ecu,conversion harness and run all obd1?
R.I.P BEN LEE2/24/08 we love and miss you http://burnoutbox.activeboard.com/in...BID=127652&p=1 GOOD FAST CHEAP, you can pick only two. fast and cheap isn't good good and cheap isn't fast good and fast isn't cheap |
Obd-1 is the way to go on that for proper tuning and reliability just a pricey conversion.
Monotech 88-91 Dx to Mpfi conversion harness |
#5 | |
I finally found some better diagrams that showed the polarity of the TDC sensor in the Distributor. I should only have to pin the wires into the other style connector and swap the tdc around, rewire the map. It will RUN with out chipping, but I'll chip it with the d16z6 maps and it should run just as well as otherwise. I don't even need a 4 wire 02 for the pr3, though they are more accurate so I'll wire one in. |
#6 |
I'm told it will. With an adapter plug or swapping the plug on either the car or the distributor and swapping the tdc sensor polarity... Guess I'll let ya know when I try it. That'll be a week or so until I get a chance to work on it again. Holidays are a bitch...
#7 |
So, the car I heard of that was running a pr3 on a D16z6 had one of those hard as shit to find OBD1 PR3's. I started looking at the code in the computer that controls the distributor, hell no. That would take me a week to write a new code in the obd0 computer to control the obd1 distributor...
So, I went junk-yarding and got me an obd1 p28 with connectors and a length of wire still attached... Gonna chip it and sacrifice a pm9 I have layin around to make a obd0-obd1 jumper... already re-pinned the distributor plugs, removed the injector resister box, and am hooking up all my other senors. I'll post up how it goes incase anyone reads this. ha. |
#8 |
¿GANGSTA GREMLIN?
Ride: 91 CRX si
wh wouldnt you just by te conversion harness from rywire,get an obd1 dizzy,ecu and call it a day?
#9 | |
It's just an extra project, i'll try something new and try to keep it cheap. I got time... the jumper harness and converting the ecu, aren't all that hard. I'm into the ecu and jumper harness about $70 $25 for the ecu at the junk yard $16 for the chip kit and $20 for the ecu conversion kit. + $8 for shipping Instead of $80-$120 for a chipped P28 and $50-$100 for a jumper harness. I'm actually surprised how cheap this is working out... Takes a lot of fucking time to research everything since I'm used to gm and ford. But couldn't resist getting me a honda... So, anyone have any suggestions for a good, budget Header? Right now I have a 91 D15 stock manifold on it just for start-up(it'll through an O2 heater circuit code, but should start just fine) |
| Tags |
| chipped, crxsi, d16, d16z6, distributor, dizzy, fuel maps, maps, obd0, obd1, pm6, pr3 |
| d16z6 head on a obd0 1.5 block? | HondaElite | Civic and del Sol - EG and EK | 10 | 02-14-2008 03:45 AM |
| D16Z6 Integra OBD0 | Gophat | ECU's, Electronics, and Tuning | 3 | 12-08-2007 10:01 PM |
| need to replace stock obd0 harness with another obd0 | JdmFr0g | HYBRID -> ED-EF / DA | 3 | 01-15-2006 09:27 PM |
| 1990 CRX Si with d16z6 swap issues OBD0 - OBD1 | Z6CRX | HYBRID -> ED-EF / DA | 23 | 09-14-2005 05:26 PM |
| WTT!! D16Z6 Harness for OBD0 d15b2 | MugenHonda91 | Parts: For Sale/Trade/Wanted | 3 | 02-08-2005 08:15 AM |
