d16z6 swap ? obdo-1 conversion?
Old 01-25-2005, 09:02 AM   #1
88rex is off the scale
Thumbs up
i'm doing a d16z6 swap in 88 rex i have read alot of info on this site about this swap but i have a few? should i use jdm vtec ecu w wich is obd0 and convert this engine over to obdo?or should i get the ecu jumper and run a p28 and keep it obd1? does the jumper harness have the 4wire o2 hookup and the obd1 dizzy hookup also the fuel injector plugs are different.does this jumper harness fix this or is there another one that does the engine bay .i saw there were extra wires coming off of it is that where the go also does this include vtec wires?
88rex is offline   Reply With Quote
Old 01-25-2005, 08:42 PM   #2
I wear stretchy pants
Taco15's Avatar
Ride:  chevy s-10
Taco15 has a reputation beyond reputeTaco15 has a reputation beyond reputeTaco15 has a reputation beyond repute
myspace
man we got the same problem. Same car, same year, same motor, except ecu. Im still looking for my p28.
Taco15 is offline   Reply With Quote
Old 01-27-2005, 09:01 PM   #3
Wiring Guru
JKOBD.com is off the scale
My conversion harnesses come with very detailed instructions for an easy installation. Injector wiring, distributor wiring, sensor wiring, etc is all covered with the harness instructions. The extra wires that come off of my harness are for the extra sensors. They are all color coded for an easy installation.
I also have P28 ecus in stock as well.
Jason
www.JKobdconversionharness.com
JKOBD.com is offline   Reply With Quote
Old 01-30-2005, 02:27 PM   #4
hybrid4 is off the scale
I have the same swap. I just stayed obdo with a pr3. Or pw0, whatever you prefer.
hybrid4 is offline   Reply With Quote
Old 01-30-2005, 10:38 PM   #5
vega_box is off the scale
i'm joining the club cuz i am also doing the same swap but in a 88 civic. also i got my conversion harness Jason. Although I have finished the motor yet good instructions. Buy from him
vega_box is offline   Reply With Quote
