I am having problems getting my swap running, I need some parts prolly.
I'm not getting spark but I also am sure my crx si distributor wont work which I paid 250 from napa to buy.. I need a d16z6 distributor maybe even a wiring harnes from a eg civic ex/si I also prolly need a ecu from the same civic I jus mentioned. I was wondering if it would be possible since I bet it'd be cheaper to find one if I used a crx si wiring harness/ecu and jus swap the distributor clips from my crxsi dizzy to the z6 dizzy which will bolt up to my vtec head.. idk need any help and parts |
ambitious...but rubbish
Ride: 91 Si hatch GSR swap
a crx Si distributor will work on a Y8 vtec head so it should work on your Z6.
you will be needing P28? ECU frim a single cam Vtec, 92-95 EX/Si or del-sol Si. a Rywire kit to convert your harness to OBD1 will make the job so much easier, you will also need to run wires for your VTEC solenoid, knock sensor and maybe an O2 sensor. you should make good power with this setup, take your time and double check everything to prevent problems, good luck! |
Got Rice?
Ride: 89' CRX HF and 90' Civic Si
^^^yeah rywire will make things a lot easier
www.supremacyracing.com |
| d16z6 , head , Vtec Harness | MiamiEgGSr | Parts: For Sale/Trade/Wanted | 8 | 12-31-2007 06:00 PM |
| EG8 Vtec head onto non Vtec | ejclide | HYBRID -> EG-EK / DC | 10 | 04-27-2007 07:16 AM |
| d16a1 DOHC head onto d16z6 SOHC block? | civic2nr9177 | HYBRID -> EG-EK / DC | 1 | 03-22-2004 12:14 AM |
| B18A1 Can I add VTEC? | psychochicken | HYBRID -> ED-EF / DA | 9 | 01-19-2004 10:31 PM |
