Dpfi--->mpfi 911
Old 10-08-2006, 01:58 PM   #1
Old School Imports FTW
1990civic's Avatar
Rep Power: 0 1990civic is on a distinguished road
Default Dpfi--->mpfi 911
In the instructions for the swap found on this site it says, for the distributor wiring, Match up the two white wires, the fat one with the fat one and little with the little. Mine both appear to be the same size?
1990civic is offline   Reply With Quote
Old 10-08-2006, 03:05 PM   #2
1990civic's Avatar
is anyone here familiar with the HF setup?
Old 10-08-2006, 03:38 PM   #3
1990civic's Avatar
anyone?
Old 10-08-2006, 03:57 PM   #4
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
They should be different sizes, if only slightly so. You could always hook them up temporarily with some twist nuts, then switch them if you throw an ECU code.
Old 10-08-2006, 05:21 PM   #5
jlicrx's Avatar
the 2 white wires - one is for the igniter and one is for the Crank sensor - the igniter wire is the fatter and is located as shown in the attached picture - if you have already de-pinned them, you can open up the harness back a little ways from the connector and you will find that the crank sensor wire is inside of shielding (kind of like inside a tube) - the crank sensor wire will also have little red hash marks spaced out along its length - you can also check for continuity on the white wires, check between the distributor end and the ECU end at pinouts B15 or B17 (these get connected together inside the harness and become the same wire) - the one with continuity would be the igniter wire
ZCspeed Racing
Old 10-08-2006, 10:24 PM   #6
Rep Power: 7 b20b.eg is on a distinguished road
i had the same problem at one time i just took a guess and was wrong the first try then swaped them then i was ready to go
b20b.eg is offline   Reply With Quote
« sensor plugs | help »
dpfi mpfi swap.. help!!! spider HYBRID -> ED-EF / DA 5 04-28-2008 09:42 PM
OBD1 distributor on OBD0 DPFI harness PiXeL HYBRID -> EG-EK / DC 1 09-23-2006 11:56 AM
help with dpfi to mpfi on a b18 into an 89 hatch delsol_racer HYBRID -> ED-EF / DA 1 08-19-2006 03:07 PM
F/S dpfi to mpfi EVERYTHING needed ! JHJames20 Parts: For Sale/Trade/Wanted 1 08-15-2006 11:18 AM
DPFI TPS and fuel injector questions kdinger General Tech and Maintenance 6 07-25-2006 10:58 PM
