DPFI to MPFI help!
Old 04-30-2007, 03:11 PM   #1
EF2 owner
Ride:  1990 Honda Civic LX (EF2)
Rep Power: 6 InspireGarage! is on a distinguished road
Send a message via AIM to InspireGarage!
Default DPFI to MPFI help!
So i just finished up my MPFI swap on my 90' Civic LX. The motor is a D16Y7 that i bought from a buddy that had the stock PM5 dual point manifold on it. So i did the MPFI swap on it. But i have ran into a problem. My computer is running in limp mode, and flashing a code 4 (crank sensor). Therefore i can't go past 3200 rpm. I have used an OBD2 LX dizzy, and just used the boomslang OBD0 to OBD2 wiring how to. I know all of my wiring is correct i have gone over it 10 times, and even had some buddies go over it. Now i have done this before, with no problem, but i have no idea what the problem could be. I have been told to switch around the big white to the small white, and the small white wire to the big white. And the car doesn't even start. I went ahead and switch out the internals in the dizzy, and still nothing. If someone has an idea please help me out. By the way i have been using a PM6 ecu. It does the same thing with the PR4 ecu. Thanks!
EF sedan owner
InspireGarage! is offline   Reply With Quote
Old 05-01-2007, 10:40 PM   #2
K2e2vin's Avatar
Ride:  88 Honda Civic HB
Rep Power: 150 K2e2vin has a reputation beyond reputeK2e2vin has a reputation beyond repute
Send a message via AIM to K2e2vin
On the OBD2 engines, isn't the crank sensor at the crank instead of the distributor? Or is that the D17s???
Someone help this guy out!
1988 Honda Civic Standard-more mods than I want to list
1992 Honda Accord LX
1996 Toyota Avalon-Spun bearing, for sale.
Terrorists have successfully attacked our imagination.
RIP
Jon Eban Nie, August 31, 1991 - May 7, 2006
Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006
Old 05-02-2007, 12:47 PM   #3
EF2 owner
I thought the same thing. I believe when the guy did the swap, he had taken in off in order to run the stock PM5 dizzy, and dual point. Is there anyway i can get a new one from and OBD2 motor, and then just wire it up? What would be my best bet?
EF sedan owner
Old 05-03-2007, 11:21 PM   #4
fixed4 life's Avatar
Ride:  91 DA
Rep Power: 7 fixed4 life is on a distinguished road
Send a message via AIM to fixed4 life
I had the same problem on my mpfi swap. My set up is an ls with and obdo pr4 ecu and a obdo dizzy. At first i was running a pm8 ecu and everytime i tried using a pm6 or the pr4 it would throw a code 4 also so i swapped distributor with one that i new worked fine and it would still not work but for some reason only the pm8 worked. I checked over all my wiring i checked the CPS wires i ran into th ecu and everything was right. It still does it to this day sometimes. Check your CPS wires that you had to repin and make sure they are not loose when mine messes up all i have to do is move the wires around and unplug them (the whole plug not just the 2 wires)and replug it. If i move my ecu or wiggle the wires where the cps wires are it either shuts off or throws the code 4. Dont know if this helps you but i fell your pain it took me 4 months after my swap to finanly fix the problem. techinally the problem isnt fixed because it still does it but i know what to do to make it work. Try geting a pm8 ecu everytime i used it it never threw a code 4 .
fixed4 life is offline   Reply With Quote
Old 05-04-2007, 12:20 AM   #5
EF2 owner
Alright i will do that. Thanks for the help man. I'll let you know how that turns out!
EF sedan owner
Dpfi Mpfi Swap Problems fixed4 life Civic and CRX - EF 1 10-06-2006 05:11 PM
DPFI MPFI SWAP problem fixed4 life HYBRID -> ED-EF / DA 0 10-06-2006 12:18 AM
1989 Civic DPFI to MPFI conversion. dj30224 HYBRID -> ED-EF / DA 1 09-04-2006 08:49 PM
dpfi -> mpfi ?!? Need help! FredrikB Civic and del Sol - EG and EK 1 08-22-2006 10:09 AM
F/S dpfi to mpfi EVERYTHING needed ! JHJames20 Parts: For Sale/Trade/Wanted 1 08-15-2006 11:18 AM
