angry bear
Ride: 02 Acura RSX
So in my crx I am running a civic Radiator and not my stock crx radiator. I notice that my ect switch(engine coolant temperature) has nothing pluged into it. I know it controls the fan on the radiator. and I also know that the stock crx radiator has the ect switch in it. I need help figuring out what plug from my stock harness do I need to use to extend the wires to the ect switch on the back of the b16 block
XBL: ripperbone Vouches / Good buyers or sellers = * pissedoffsol* socolsvtec* lshatchcx18* hybrid89* aafryf* integraracing91* twistedimage* NoJokE* 5speed4life* Estorvito* sheekdude* antonio* VTECPOWER* 98hybrid* traitorzxiong* preludebuddy* wanderinman* TurboMirage* kaoskustoms* B16RacerN2NR* HPHP80620* |
you crx should have had it on the back of the block as well..i had to move mine from the back to the thermostat housing. looks the same on first gen b16's as obd0 d's
*New Ride* 1998 Black DX Hatch build it....break it....build it....break it...it's a vicious cycle SOLD: 1988 Honda CR-X Hf Performance: 1998 D16Y8, 1988 Si Tranny, D16a6 injectors,PM6, 88 accord clutch disc, 91 and up Flywheel and Pressure Plate, Comp Cams 260 Street and Strip CAM, RPM Switch for VTEC(saving up for Hondata ECU) DC Sports 4-1 header, 2.25 Exhaust, High flow Cat, Cold Air intake, b18c5 throttle body Floss: JDM Power Window Conversion, Arm rest, EDM door pockets, 91 si gauges, 91 Si taillights, full Si interior swap,and 96 gsr wheels w/kumho ecsta 711's, and projectors. Suspension: Koni Sports, Eibach Pro's, Rear Sway Brakes: 1" Master cylinder, ITR calipers and brackets, 90-91 ex knuckles, redrilled Prelude VTEC rotors up front and 98gsr disc in the rear Future mods include: WW RS KIT, S2000 Suzuka blue metallic paint, Power folding mirrors, obd1 hondata, BOOST!!! |
angry bear
Ride: 02 Acura RSX
is it a brown plug?
its a big rubber shrouded thing with two bullet style connectors inside
#5 |
angry bear
Ride: 02 Acura RSX
heres picture of what I am talking about.
![]() its not the greatest picture had to use a camera phone __________________
#6 |
yeah just extend those 2 wires off the back ur block onto that brown connector, and woosh u have a coolent temp. its pretty easy and i dont htink it matters what order the wires go on. since ones a ground n the others the signal. or well at least i havent had a problem with that ne ways. but yes the gentlemen above was right its a black rubber thing thats probally all cracked n broken that holds the wires for the coolent temp.
89 EF build: Poorman's ITR 95 GSR bottom end, .25over b16 pistons Pr3 Zealautowerks compression = 11-8-1 ARP head studs, Stock head gasket S2 Pro series IM, w/ Hondata intake gasket Holley 68mm throttle body ITR 4-1 header, w/ 2.5 in magna flow exhaust ( sounds niceeeee btw) kteller 2.5 mandrel bend kit. PnP b16 head w/ dual valve springs and ITR cams Milled about .030 AEM hybrid CAI Running obd1 w/ p28 tuned on chrome Made 178 at churches w/ 2in exhaust and dc 4-2-1 header w/ 2 in collector. |
#7 |
angry bear
Ride: 02 Acura RSX
do you happen to know the colors of the wires, cause when I took the picture I looked and didnt see that black rubber piece anymore, I remember it on my d16 when I pulled the wiring harness,
#8 |
i believe they are yellow, probally turning brown from the heat, and are mostly likely really dried n cracked. lol in simple look for something thatisnt pluged in and there ug o
#9 |
angry bear
Ride: 02 Acura RSX
found the problem, the 2 wires were splice together to have the fan on constant, and the fan was plugged into the a/c fan plug. so I plugged the fan into the right plug and I am going to get a connector and extend the wires.
and yes the wire was yellow, thanks __________________
