ecu/ feul/spark problem
Old 12-20-2006, 10:55 PM   #1
honkey tits
Rep Power: 0 B16Ablacky is on a distinguished road
Send a message via AIM to B16Ablacky
Default ecu/ feul/spark problem
i just dropped a jdm b16a into my 91 integra gs. everything is hooked up mechanically and electrically, or so i think. i used the obd0 to 0bd1 coversion from rywire.com. now when i finally with the swap i tried to start the car and it would turn over but no start. i later found out after some tests that my fuel pump wasnt turning on and i was getting no spark. then i just 2day tried putting my old obd0 non-vtec ecu back in place and turned the key and my fuel pump turned on but i still got no spark. what are some possibilities on what my problem is? i was thinking maybe the new ecu(pr3) i somehow "bad" or the ecu jumper harness is "bad."
any help is much appriciated
B16Ablacky is offline   Reply With Quote
engine start problem LJK ECU's, Electronics, and Tuning 3 01-02-2007 04:47 PM
engine start problem LJK Civic and del Sol - EG and EK 0 12-17-2006 05:57 PM
88+ ECU Error Codes pissedoffsol Reference Materials 1 05-19-2005 01:03 PM
Can't Find Problem...Everyone needed AJBurks ECU's, Electronics, and Tuning 6 02-25-2005 03:38 PM
All Swap Info for EF Riceras HYBRID -> ED-EF / DA 2 02-07-2005 03:20 PM
