Ef Sedan swap Questions..
Old 09-28-2006, 02:09 AM   #1
Rep Power: 0 eklum is on a distinguished road
Default Ef Sedan swap Questions..
hi im new here searched a little bit but im wondering if somone could tellme straight up since theres not alot of threads covering ef sedan swaps.only crxs basicly....
if i had 1991 civic sedan and wanted to put
b16a obd0 swap into it what would i need to do
what mounts/brackets do i need to get
how hard would it be to wire ( ive wired a obd2a civic dx harness to run a obd2a b18b before..)
what would i need to do about the tranny / shift linkage ( iunderstand id need to trim the linkage by 3 inches to get it to fit??)
im also comptemplating
putting in a b18a becuase itd have a higher chance to smog and def. cheaper.
so could i run a 1991 integra ls ecu with a stock ef harness ?
eklum is offline   Reply With Quote
Old 09-28-2006, 08:38 AM   #2
Andrew's Avatar
Ride:  1991 CRX Si
Rep Power: 47 Andrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to behold
Send a message via AIM to Andrew
You will need the same stuff as other 88-91 civic/crx's.
EF's are all, for the most part, the same.
So everything you see done to CRX's, you'll be doing to your car.
Type in "b16 crx" and you'll be overloaded with info.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
d16z5 swap into a 92civic sedan FredrikB HYBRID -> EG-EK / DC 1 08-21-2006 09:23 AM
92 prelude swap questions Dark91zc HYBRID -> BA-BB /CA-CD 8 09-18-2005 02:11 PM
Huge swap question(s) boostdlude HYBRID -> ED-EF / DA 4 01-26-2005 09:54 PM
ZC Swap Questions wht91dx HYBRID -> ED-EF / DA 6 09-29-2004 04:54 PM
B18C swap in 91 crx Si, lots of questions 99SH HYBRID -> ED-EF / DA 1 03-26-2004 03:06 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
