Engine Trouble
Old 04-24-2007, 09:11 PM   #1
Rep Power: 0 Jayamashey is off the scale
Default Engine Trouble
Need some help with an engine problem.
I completed a B16A SIR2 swap in the fall. Everything was running great until the weekend.
I drove it about 30 miles (50km) and it ran fine. Then i washed it and sprayed the engine bay down just with the hose. Then some guy came over and test drove it by himself (I am selling).
After he got back I started it and the engine is now studdering (especially in lower RPM). It feels like its misfiring and definately underpowered, but I am not getting any codes. When I accelerate in neutral and hit 4000-5000 RPM it makes a terrible noise (almost like loose heatshields), but over is better. It seems to shake/shudder alot in the lower RPMs when gas is given. Idle sounds OK but is a little more rough then normal but doen't have the shudder.
Any ideas?
BTW: Plugs, wires, dizzy, timing belt, O2 - are all 3 months old and worked well.
Jayamashey is offline   Reply With Quote
Old 04-24-2007, 09:13 PM   #2
HS TECH
AHHVTEC's Avatar
Ride:  dc5,mk4 gti,2nd gen civic,
Rep Power: 164 AHHVTEC has a reputation beyond repute
AHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond reputeAHHVTEC has a reputation beyond repute
it sounds like water got in something mabe the dizzy cap
Old 04-24-2007, 09:17 PM   #3
TheManRSW
Ride:  1995 Honda Del sol Si
Rep Power: 8 TheManRSW is on a distinguished road
Send a message via AIM to TheManRSW
^^^ pull the distributer cap and make sure all is dry.
TheManRSW is offline   Reply With Quote
Old 04-24-2007, 09:34 PM   #4
Thanks, but that was the first thing i check and it was dry.
Also car almost bogs to a stall on idle . But runs better in the higher RPMs (over 5000).
Old 04-24-2007, 11:47 PM   #5
jason91si
Ride:  1991 honda civic si b16a
Rep Power: 4 jason22ga is on a distinguished road
Send a message via AIM to jason22ga
take your spark plug wires out off the head and see if you got water in the spark plug holes mine done the same thing when i washed my engine hope this helps
jason22ga is offline   Reply With Quote
Forum Jump
Honda CRX Del Sol B16a.... Will a B18 engine swap work!?!? Hel CRXDRESOL General Tech and Maintenance 4 03-31-2007 08:44 PM
ecotec tweakman Members' Lounge 22 09-29-2003 03:23 AM
Engine Trouble haccord141 General Tech and Maintenance 15 04-09-2003 01:01 PM
Engine Trouble Con't haccord141 General Tech and Maintenance 1 04-08-2003 03:20 PM
What is double clutching? Calesta General Tech Articles 0 12-27-2002 03:06 PM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
