Ok so i have always been a sohc person. I have had my share dual cams, and love surprising people with off the wall crazy built sohc. So this one is a new swap for me. If anyone has any help i really need all that i can get. Thanks A lot
HS Vendor
Location: 650n Barranca ave #a Covina, Ca 91723 (626) 261-4052
Ride: 00 Civic, 08 Fit, 98 EK
It's basically the same as doing an H22A swap... Mounts, Axles, etc... Unless you are using the Prelude version though you will have to use SOHC Prelude post bracket. Personally I think it's a lot of work for what you are going to get out of it but people will defiantly be surprised when you pop your hood.
88-91 Honda Civic/ CRX EF H-Series Swap, DIY __________________
http://www.SwapShopRacing.com Honda Performance (626) 261-4052 attn: Brian http://www.myspace.com/swapshopr http://www.facebook.com/swapshopracing http://www.twitter.com/swapshopracing |
#8 |
The name's Sam
What motor exactly? You could swap on a couple different heads to increase power a bit. f22b2, f23a1, maybe even the non vtec f22a4 head, I have seen people run h23 heads on the f22 blocks as well but if you wanna stick with sohc I would go with the b2 probably. But either way I am glad to see another sohc guy sticking to them. I debated on a b18 swap in my civic when I blew my motor but ended up buildin a mini me instead.
Parts for sale: http://hondaswap.com/parts-sale-trad...-parts-115446/ Build Threads: Civic: http://hondaswap.com/civic-del-sol-eg-ek/d16y8-n-build-112401/5.html Trans Am: http://hondaswap.com/other-vehicle-discussions/1980-trans-am-build-thread-oh-yeah-its-official-149941/#post1054318 |
#9 |
D-Series Ninja
Ride: 90' Honda CRX Si
SOHC's are going a long ways these days. Speed Factory just ran a 10-second D16y8 with a bad trans and stock cam. Using a nasty 600+ HP Vitara Setup. If they would change the gears and introduce a cam they would easily break into 9's.
#10 | |
Big Member
Ride: 1992 Honda Accord, 1990 CR-X, 2003 Buell Blast
I wanted to swap an H22 for a while, but when I realized that I could put just as much power down with a good turbo and tune, I figured I'd stick with the f22 and rebuild if I have to, but then I remembered I have no money, and decided to drive it till it dies. F22 would be pretty cool. Built SOHC is always respectable. Good luck!
#11 |
HS Vendor
I recommend using an H22A half shaft and H22A EF swap axles if you can.
#15 |
ok sorry i could not post anything yesterday my computer took a shit im not really to sure what the motor is for sure the car is sitting at my buddies shop and i guess my little rex got nominated for the swap so i need h22 axels and half shaft for an ef i heard from some where the the b18 axels will work is this true or is someone full of shit
#16 |
Boosted Rex
Ride: '90 CRX SI
I see good 'ol SwapSwap poped in on this thread.
Love your guys products ![]() But, glad your sticking with a SOHC. ![]() Pics when it starts !? __________________
Boost is not a hobby, It's pure addiction. Wanna check out my build progress? http://www.cardomain.com/ride/3029308 |
#17 |
i will deff have pics up as soon as i start on the swap im takein it to my buddies shop on wendsday
so excited im just doing stock si right now till i have everything for the f22 plus i wat to do complete rebuild and bore and head work you know all the works before it gets put in |
