went for e test today. failed.
got a 90 integra, with a b16, with hi flow cat. i just bought it. heres the numbers. @2500 rpm HC PPM Limit 200; reading 292 CO% Limit 1; reading 4.24 NO PPM N/A RPM 2659 DILUTION:16.26 @Idle HC PPM Limit 200; reading 345 CO% Limit 1; reading 2.91 NO PPM; N/A RPM 894 DILUTION:15.73 I was just wondering how bad these numbers are. it went with no tune up. oil in the engine was still a gold color. should i change the o2 sensor along with a tune up?,based on these numbers. or just do a tune up. |
#2 | |
Ride: 2001 Jeep Cherokee
Your HC (Hydrocarbons) were fuckin high, which basically means you have unburnt fuel. So i would recommend doing a tune up and get some better spark plugs so they burn better, and some decent wires. I also heard on another thread that you can buy a fuel pressure regulator, and turn it down, then go take your smog test.
yeah those numbers are preety high. . .do the tune up, check all your vacume lines, retard the timing, check to make sure you charcol box is hooked up (haha mine wasn't and i got numbers like those) and do a search about this, i know theres some more, i just can't remember, anyways my b16 passed ca emissions so don't give up
#9 |
your high flow cat maybe the problem, look on it to see if it has a CARB or EPA # on it, as a lot of times cats listed as high flow cats are not legal cats, and do less than a real cat. Also replace your pcv valve, it is cheap to fix.
2004 Toyota Tacoma 3.4L V6 TRD Package 4WD ---------------------- |
#11 |
there was a post in here earlier about the cheapest way to fix this:
goto your local hardware store and get some (goofy ass named) alcohol, denatured i believe, and poor some in your tank, make you run lean while not hurting your engine. __________________
<span style=\'color:gray\'>I get paid to read e-mail, and click links.</span> <a href=\'http://www.MikesPaid4Email.com/pages/index.php?refid=cointelpro\' target=\'_blank\'>SO CAN YOU!</a> |
#12 | |
Yup, exactly. run 66% alcohol, 33% Gas. And don't be smart asses about the percent, if you want it perfect, then 2 parts alcohol, 1 part gas
#13 |
Ride: 91 CRX
you still need to get the motor up to temperature as well.
a properly warmed motor will have less HC and CO, but too hot an your Nx goes up. __________________
Dennis Buy my stuff plz... Mondaswap For Sale - MPFI, 88-91 CRX, 92-95 Civic Parts Please don't PM/Email/IM me for technical support. Make a Post!!! 91 CRX DX, 03 Civic EX "There are 10 kinds of people in the world: those who get binary and those who don't." "Of all my imaginary friends I don't think there was one I didn't end up having to kill" |
| Car failed air care | wisemansoji | HYBRID -> EG-EK / DC | 5 | 06-30-2004 12:24 PM |
| CART numbers available | number9 | NorthEast | 19 | 01-31-2004 07:46 PM |
| Numbers On D16y8? | Riceburner | General Tech and Maintenance | 1 | 05-14-2003 04:26 AM |
| Failed Emmissions | Sporty240 | General Tech and Maintenance | 11 | 03-28-2003 12:44 AM |
| Whats All Them Numbers Mean? | Canuck 93 Civic Si | Forced Induction | 1 | 03-01-2003 07:01 PM |
