A Few Simple DOHC ZC Q's
Old 08-27-2007, 11:48 PM   #1
Rep Power: 5 jcl8706 is on a distinguished road
Default A Few Simple DOHC ZC Q's
I recently bought an 89 hatch w the blacktop dohc zc swap and the wiring to the ecu and sensors is hacked. Is there a good link or reference anyone has to what the correct wiring for the swap would be?
The car has a PM6 ecu, would it benefit it alot to get a PM7 ecu?
The O2 sensor has the insulated signal wire with wire wrapped around the insulation, anyone know which goes where?
Ive done alot of research and its supposed to be a decently quick car with the swap, but this thing has no balls under like 4500..timing marks are dead on..any suggestions?
Help=good! Thanks
jcl8706 is offline   Reply With Quote
Old 08-28-2007, 12:20 AM   #2
Rep Power: 6 spinninhonda is on a distinguished road
first off d-series.org for the wiring, and yes a pm7 helps alot, or just have the pm6 chipped with a pm7 basemap and get a tune, i put a friends form 15.5 to 14.8 on just a tune with an intake header and exhaust
'88 crx dx
b18a
eagle crank and rods
crower cams
2-angle valve job
arias pistons
victor X intake mani
nitrous express 75 shot
walbro 255 lph fuel pump
dc sports 4-2-1 header
2.5" n1 header back
pass. jdm carbon intake
Installed, i have wiring, the widebody molding, and driving before more mods come
spinninhonda is offline   Reply With Quote
Old 08-28-2007, 12:47 PM   #3
jlicrx's Avatar
what model is the car? DX or Si? wiring varies with model - PG7 ECU from 88-89 Integra will also work about the same as the PM7 - both have higher rev limiter than the PM6 - doe it have Check Engine Light and codes? are you sure that camshaft timing is correct? do you know what transmission it has?
ZCspeed Racing
Old 08-28-2007, 05:20 PM   #4
Its an Si, the CEL comes on and stays on after it runs for a little while, I already retimed it and its dead on. Throwin codes 17, 1, and 20.
The trans was a DX, but I swapped out the ring gear and pinion shaft to the SI 4.25 gears because I had to replace a bad shift fork.
Old 09-06-2007, 01:32 PM   #5
Well I got the usdm 89 teggy ecu.. it helped, but still throwin codes.. Some of the wire colors on the plugs dont match what ive looked up in the chiltons or haynes, or the online forums, a few are cut off the plugs that dont match, and a few are cut off the harness that are hanging that dont match..
Old 09-11-2007, 03:46 PM   #6
Banned
Ride:  88 honda crx si
Rep Power: 0 1988hondacrxsiR1 can only hope to improve
What Are The Codes? On The Integra Ecu.
1988hondacrxsiR1 is offline   Reply With Quote
Old 09-11-2007, 03:47 PM   #7
Banned
THE PM6 SHOULD WORK FINE. WhAT WERE THE CODES ON THAT BEFORE?
Old 09-12-2007, 11:33 AM   #8
Its throwin 1 (o2 sensor), 9 (cyl 1 position), and 20 (electronic load). Timing is balls on, used the timing writeup from zcspeed.com. Is the electronic load pos in the fusebox under the hood or under the steering wheel? Im going to buy a generic 1wire 02 and see if that goes away, and will try switching the wires on the cyl position sensor to see if that fixes it. My wiring's hacked at the ecu, butt connectors and a couple wires hanging, few wires that dont exist on the schematic lol..
Old 09-12-2007, 12:03 PM   #9
Banned
BUy a manual and follow color wire and code #20 does not exist in my data. GOOD LUCK!
Old 09-12-2007, 12:20 PM   #10
jlicrx's Avatar
the ELD is in the underhood fuse box - not replaceable without replacing the entire fuse box - if the car is a Canadian model, i don't believe it has ELD
ZCspeed Racing
Old 09-12-2007, 01:36 PM   #11
Banned
ditto
Old 09-12-2007, 11:08 PM   #12
Well regardless, its throwing a code 20. I bought another o2 sensor..didnt fix it. Switched the wires on the cyl pos sensor..didnt fix that either. These sensors are zc only, not teggy correct?
Old 09-13-2007, 11:08 AM   #13
jlicrx's Avatar
88-89 Integra Cylinder sensor is the same as the DOHC ZC
ZCspeed Racing
Old 09-13-2007, 05:20 PM   #14
Banned
all o2 sensors are the same for ef and ed and da
all that ef ek all are different minus emission cars they are bigger
Old 09-14-2007, 08:49 PM   #15
Ya i meant to ask if *the cylinder pos sensor is zc only*..but thanks, i might have to go get one
Old 09-15-2007, 10:48 PM   #16
Rep Power: 13 blackice90HB is an unknown quantity at this point
I got one 35 shipped. 88-89 tegs with the D16A1 motor have tose CPS, just like your DOHC and the D16a8/9. other D-series are single cam and dont have them, they are in the distributor. Easy fix is to run a Si dizzy, but you will have to re pin it and only one bolt lines up. I have a re-pinned Si dizzy to for 60 shipped. With the Si dizzy you dont need to have the CPS plugged up, just bolted in to keep it from leaking oil
Im gonna redline inline 4's until I flatline.........
1990 Honda Civic STD Hatch
DOHC ZC, Finally
PG7 ECU,
Neuspeed Springs
Currently hunting for 16"/17" Enkei OR52's and a camber kit
*vouches for sellers:* HatchSpeeD, B16RacerN2NR, Phyregod
blackice90HB is offline   Reply With Quote
Old 09-19-2007, 01:51 PM   #17
Well I got the 02 problem fixed, the wire going into the harness was repinned to a different socket...i dont understand why the chickenfooker before got everything a$$-backwards.. cyl sensor is correctly pinned with no shorts to ground..going to recheck timing this weekend otherwise goin to get a know good sensor! The wire going to the ELD is just hanging, and cant figure out where its supposed to be pinned so whatever i guess haha
Old 09-21-2007, 08:56 AM   #18
Banned
You are noob.
Old 09-21-2007, 09:46 AM   #19
HS Troll...And Mod
reikoshea's Avatar
Ride:  2001 Honda S2000
myspace
you are perma banned.
Anime Informant
reikoshea is offline   Reply With Quote
Old 10-17-2007, 11:50 AM   #20
k or not
B16A2 in my 97 civic ex...still slow! pinto Civic and del Sol - EG and EK 15 06-19-2009 11:25 AM
b16a obd 0 tune up parts list feet_ HYBRID -> ED-EF / DA 6 12-27-2007 08:50 PM
DOHC ZC vtec cast wanted demonboy1300 Engine Building 9 05-10-2007 07:53 PM
DOHc Vs SOHC mark80 General Tech and Maintenance 10 05-12-2006 01:41 PM
Part Numbers for 89Si/B16 OBD0 Swap steelbuster Swap Articles 0 11-16-2003 07:36 PM
