Filling a YS1
Old 08-14-2004, 08:58 PM   #1
Rep Power: 0 offroader is off the scale
I'm attempting to fill my 93 YS1 manual transmission. I was reading an online article that shows the fill plug as being a small plug on the very end of the transmission which requires an alan key to remove.
I tried and tried but the fluid keep pouring out....Rrrrrr it was frustrating. Then right next to the tanny mount I noticed a small hole with a rubber stopper on it. I removed the stopper and tried pouring the MTF in there...it would not take...until I removed the plug from the end of the transmission. THis seemed to allow air out, and it took 4 quarts.
It runs ok...so far. Can anybody tell me if I pout the MTF in the right spot? It has not spilled out frm anywhere...is that possibly actually some sort of vent....but would work for a fill hole?
Please let me know ASAP if you know the answer...as I'm nervous I did the wrong thing?
Mark
offroader is offline   Reply With Quote
Old 08-15-2004, 02:07 AM   #2
Rep Power: 17 TDaddy is off the scale
Send a message via AIM to TDaddy Send a message via MSN to TDaddy Send a message via Yahoo to TDaddy
I believe mine was plugged with a 15mm bolt...you have to pump the fluid in there.. you can't just pour it in..
TDaddy is offline   Reply With Quote
Old 08-15-2004, 03:13 AM   #3
Ride:  i have 14 cars i drive my sohc turbo ef
Rep Power: 53 97hatch has much to be proud of97hatch has much to be proud of97hatch has much to be proud of97hatch has much to be proud of97hatch has much to be proud of97hatch has much to be proud of97hatch has much to be proud of
there is a 17mm bolt on the back of the trany you sould fill it till it is runing out and plug it again. you have to much oil in there pull the fill plug and let it drain some off. you trans olly holds 2.1qts
97hatch is offline   Reply With Quote
