I have a 1991 si hatch with a b16a1 from a JDM integra xsi, PR3 computer, and YS1 cable tranny. Basic stuff. But I am going to do a custom turbo kit and I want to upgrade the fuel injectors with some good aftermarket no modification o.e. replacements. I think I will need 450 to 500cc injectors, maybe from rc engineering. The main question i have is do I need saturated ones or peak and hold? Will I need a resistor box from a crx or something? This is all new to me so I need help from someone that knows about this stuff. How can I find out what I need. Any help will be appreciated.
thanks, djk1 |
You should stay with what ever type injectors your engine is running with. You can find out what kinda injectors you have with a multi-meter, just test the resitance. Just stay with the same resistance that your injectors already have or around there the same resistance. I think peak and hold injectors run at 1-3ohms and saturated run at 10-12ohms or some numbers around there. You could probably just call RC Engineering and they'll help you out better then me! Or someone could just tell you what kinda injectors you have, I'm not sure.
Someone correct me if I'm worng. __________________
I'll use those damn Semi-Colons however the hell I want. |
| Drag kit install manual | pissedoffsol | Forced Induction | 0 | 07-18-2004 12:37 AM |
| research paper, what do you think? | 90 accord | Members' Lounge | 9 | 06-23-2004 12:11 AM |
| What OEM number would the Fuel Injection Pressure | Moon Ill | General Tech and Maintenance | 2 | 06-07-2004 06:04 PM |
| Fuel system | Sed8ed | Engine Building | 2 | 05-26-2004 01:05 PM |
| 88 CRX DX Fuel Injection Problem | CRX-Fluffy | General Tech and Maintenance | 0 | 10-03-2003 11:43 AM |
