Ride: JRSC B20/vtec DC, Nissan Xterra SE
all integras (except Type R) from 90-01 use the same rotors and pads so i would think everyhing would bolt up. never tried it personally so i cant say 100% but im pretty sure.
#6 |
I think you need to measure the "hat" of the rotor.. Lay both rotors flat, touching and look level with them. Is one higher?? if so, you may have to shim either the rotor or the caliper.
I stripped the front brakes (rotors, calipers) from a gsr and have had them sitting til I got this 90 civ 4dr. If the distance is the same from your 90-94 DA, then you should just be able to bolt on and go. I do remember that the GSR rotors were sligthly larger than say a 89-91 Prelude si.. The spacing was too great so I never swapped them. Later this week I'll try and bolt up the gsr stuff to my 90civ and see if the bolt holes for the calipers will lign up or not. Your geometry should be OK if you just stay with swapping the brake parts. E |
#7 |
Ride: 88 Honda Civic HB
Geometry will be way off if you swap knuckles; without lowering(pretty much slam) you'll get way more positive camber with the 94-01 knuckles. The DC knuckles are physically taller. In addition to that; you have a higher risk of slamming the UCA into the shock towers.
#8 |
Ride: 91 civic hatch w/b16 and 91 civic hatch project car
I just had to change the front knuckles in my 91 hatch. The car came with 94-01 knuckles on it and i had a big problem with positive camber. I got new calipers rotors for my new da knuckles. I will try and get some pics up in the next couple of days with the rotors side by side if that will be of any help.
| CT WTB 86-89 Integra Front Hubs with brakes... | Airjockie | Parts: For Sale/Trade/Wanted | 0 | 04-02-2009 02:03 PM |
| 90 91 92 93 integra front hub rotor brakes civic 88 89 | RSS-Bot | Auctions | 0 | 03-11-2008 10:33 PM |
| 90-93 integra front disc brakes $125 | superracerhead | Parts: For Sale/Trade/Wanted | 0 | 12-19-2007 12:45 AM |
| Integra front brakes | hondahustle | HYBRID -> ED-EF / DA | 6 | 09-11-2007 07:52 PM |
| Integra front brakes | hondahustle | HYBRID -> ED-EF / DA | 4 | 09-11-2007 07:13 PM |
