Which header for B16 CRX?
Old 09-27-2006, 01:26 PM   #1
Rep Power: 7 Lemur6 is on a distinguished road
Default Which header for B16 CRX?
Looking for a header for my CRX. I know HASport makes one (or used to make one) specifically for a CRX with a B16 swap, but it's kinda pricey. Kinda looking for a DC Sports 4-2-1 header, but not sure which one fits my application.
Lemur6 is offline   Reply With Quote
Old 09-27-2006, 04:13 PM   #2
Andrew's Avatar
Ride:  1991 CRX Si
Rep Power: 47 Andrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to behold
Send a message via AIM to Andrew
b16, b18, b18c1, b18c5, b20.
B series is B series.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 09-28-2006, 04:16 AM   #3
What about the part the connects the header to the cat? I've got the stock exhaust manifold on there right now, but it's not connected to the cat (missing the pipe that goes there). Thought if I just got a header that problem would be solved, and I could just use the rest of the stock exhaust system.
Old 09-28-2006, 08:07 AM   #4
Andrew's Avatar
Ride:  1991 CRX Si
A header will bolt to your cat. I don't see where the confusion is? It's possible you'll have to take it to an exhaust shop to get your exhaust extended/shortened, but I've only heard of people doing that. I've never had to do it myself.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 10-07-2006, 04:46 AM   #5
Well here's the problem, it appears that in B16 headers for Del Sol VTEC's and 99 Civic Si's, the flange needs to be rotated (which I'd rather not do). I haven't heard whether you need to rotate the flange on integra headers though. If you've had no trouble just bolting on a header in your CRX, then what brand and model do you use?
Old 10-07-2006, 07:47 AM   #6
Andrew's Avatar
Ride:  1991 CRX Si
Oh... well then why don't you just buy a different B series header, like for a GSR, that way it doesnt need to be turned?
Any B series header will work, so just find one that will not need to be turned(the flange)... like an LS or GSR... etc...
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
b16 header vs b18 header civiclxb16 Engine Building 8 03-26-2008 11:04 PM
testing waters on JDM DC header.... GSRCRXsi Parts: For Sale/Trade/Wanted 6 02-25-2004 11:41 PM
Bisimoto Race Header? Knives Engine Building 10 01-27-2004 11:43 PM
Which DC header would fit my hybrid??? Teambypass HYBRID -> EG-EK / DC 2 07-29-2003 09:53 PM
Header Info 4 Na Junkies JDMilan Engine Building 11 05-13-2003 09:28 PM
