Facebook Twitter
headgasket for high compression
This is a discussion on headgasket for high compression in the HYBRID -> ED-EF / DA forum
Found a b18a with domed pistons 11.5:1 compression it needs a headgasket is the engine worth buying. It was just rebuilt but the headgasket is leaking was wondering what kind of issue I'm gonna run into with the higher compression. Was gonna get a performance ...
Old 06-08-2010, 09:23 PM   #1
Default headgasket for high compression
Found a b18a with domed pistons 11.5:1 compression it needs a headgasket is the engine worth buying. It was just rebuilt but the headgasket is leaking was wondering what kind of issue I'm gonna run into with the higher compression. Was gonna get a performance gasket and arp head studs what else is recommended. Complete motor for 75 bucks
MRG719 is offline   Reply With Quote
Old 06-08-2010, 09:50 PM   #2
K2e2vin's Avatar
You could use an OEM head gasket; 11.5 is not a huge jump from the B18C's stock 11.1
Only issue I'd be worried about is if the block or head needs milling.
Old 06-08-2010, 09:56 PM   #3
Do I get a gasket for a b18a or b18c
Old 06-08-2010, 10:05 PM   #4
K2e2vin's Avatar
B18a.
Old 06-17-2010, 09:33 PM   #5
Default arp studs
Bought an engine with arp studs took the head off should I remove the studs and reinstall hand tight then torque or just leave them the way they are
Old 06-17-2010, 09:57 PM   #6
K2e2vin's Avatar
If they're already still tight you can just leave them. The studs themselves are only supposed to be installed hand-tight(snug then quarter-turn) and the nuts are torqued. Remember to make sure the studs are lubed before torquing them down.
Old 06-18-2010, 05:41 AM   #7
Default rod bolts
Will I need arp rod bolts or will my stock work ok
Is this b20 the high compression one? .:i.lIKE:.:eK9:.:lOTs:. HYBRID -> EG-EK / DC 2 10-22-2006 05:39 PM
Do I have too high compression #s?? 94CivicSlow Engine Building 4 07-27-2005 05:29 AM
High compression B17 SpoonTuNed Engine Building 1 05-26-2005 11:41 PM
High or low compression w/ turbo? IntegraImport01 Engine Building 4 09-16-2004 10:24 PM
Rules on high compression and n2o jordan Engine Building 5 09-13-2003 09:51 AM
© 2001-2013 HondaSwap.com
