1. I assume these are connected correctly. Just making sure they're in the right order:
![]() 2. Moving to the back of the block...Which of these wires goes where...or does it matter??? (Yellow or black on top?!?) ![]() 3. Can someone please tell me what this is and if I need to wire it? ![]() 4. I found this ground and I don't know where it goes: ![]() 5. I just want to be sure I have identified these correctly: ![]() 6. WTF is this and where (if at all) does it connect? ![]() Thanks for the help. -Kai __________________
No tech questions through PM please! B16 CRX....you will be missed
This will be very helpfull to some one once answerd, nice pictures
Although you are missing the traditional picture....(with out the banned by call part __________________
97 Acura integra GS-R AEM cold air intake Apex-i N1 cat back Dc header best 1/4 15.4 --------------------------- |
GODDAMNIT!!!
I thought u were going to help me out.oh well...TTT ...I'm going to go put in a clutch and when I come back someone better have at least tried to anser my questions ![]() __________________
Yeah sorry to get your hopes up... one of the gods should be along here shortly.__________________
#5 |
the black ground that goes on the thermostat housing,as for the 2 yellow and black i dont think it matters wich one goes on top or bottom.As for the top green plug thats your knock sensor for the last pic i dont know wtf that is .sorry
1990 Civic Hb Si Engine B18C1:GS-R ,Eagle Rods,81.40mm Bore,Arias 9.1 Flattop Pistons,ARP Head Studs,Polished Crank,Engine Oil Cooler,92 Radiator with HI Flow Fan. Head B16:Skunk 2 Springs/Reatainers/Cam gears,Integra Type R Cams,3angle valve Job,Self Port & Polish,Type R Intake Manifold,AEM Fuel Rail,Mugen Thermostat,MSD 6A,MSD Distributor Cap,Msd 8.5mm Wires,Msd Coil,Apexi V-AFC,suspension Tokico Blue,Generic coil overs. And T3/T4 T.C, Set up Made by me. Future Upgrades:N1 Crack Pulley and TEIN SS coil Kit. My Ride: <a href=\'http://home.comcast.net/~arpee79/wsb/html/view.cgi-home.html-.html\' target=\'_blank\'>http://home.comcast.net/~arpee79/wsb/html/...home.html-.html</a> |
#7 |
#1.
looks good. just remember the injector resistor because it isn't pictured #2. i need to find out too but i don't think it matters #3. that would be your knock sensor. yes you need to wire it! #5. that is correct #6. no idea what that is! tell us what sensor it ran to before you removed the engine |
#12 |
hf resistor box will work, the last connector is for the hf's egr valve(you dont need it) just hook it up like it went you your hf and add knock sensor,oil pressure,and vtec sol wires, you also have to add a 2nd O2 or tap the 2nd o2 sensor wire to the primary and you should be set..
-joseph |
| fs b16 swap , itr head so cal | stella99si | Parts: For Sale/Trade/Wanted | 3 | 06-09-2004 11:51 AM |
| 1st gen Integra Swap Overview (da) | pissedoffsol | Swap Articles | 0 | 01-12-2004 02:15 AM |
| B16 Swap Into 1990 Teg | 90integb16a | Engine Building | 2 | 05-13-2003 10:58 AM |
| B16 Swap Kit | 1fst4dr | Parts: For Sale/Trade/Wanted | 0 | 02-11-2003 06:36 PM |
