Help B16a running problems 89 civic si
Old 05-29-2008, 02:02 PM   #1
Rep Power: 0 m00g00 is on a distinguished road
Default Help B16a running problems 89 civic si
Just to say I havent had this car running in 3yrs it was garage stored though. I am pulling codes 3,5,7. All indacate Map and tps sensor. Well i whipped out the volt meter for the tps. When close 2.5 when open .12. So i swapped the sensor out with another one. Now when close 4.5 and open .45. So i though the wires might be crossed so i switched the yellow and red. no start weird voltage. Switched back same thing. Could my other sensor be bad or is my ecu shot. I mean i map sensor being bad shouldnt throw off the voltage of the tps. Also i have a
Honda 68mm Throttle Body (P/N 112-511 & 112-540). Iam looking for some help here. Thanks!!
m00g00 is offline   Reply With Quote
Old 05-29-2008, 02:04 PM   #2
Also before storage the car ran. Throttle body stuck every so often but that is fixed now.
Old 06-08-2008, 03:48 PM   #3
Rep Power: 0 rickykline is on a distinguished road
sounds like the wiring is backwards somewhere... it should be .45 closed and 4.5 open..
rickykline is offline   Reply With Quote
b16 Swap Problems Running Rich... JuS JAi Bee HYBRID -> EG-EK / DC 13 02-08-2009 11:05 AM
89 crx problems running gunz2165 HYBRID -> ED-EF / DA 2 04-09-2006 03:28 AM
JDM B18C into EJ DX Running Problems Eskie HYBRID -> EG-EK / DC 2 11-13-2005 09:27 PM
B16 Running Problems possessed imports Engine Building 12 06-02-2003 04:38 PM
J Spec B16a Running Problems possessed imports General Tech and Maintenance 0 05-17-2003 09:10 PM
