HELP - B18A1/B1 question - and broken engine mount
Old 05-22-2006, 01:25 PM   #1
Rep Power: 0 psychochicken is off the scale
Ok, 88 Civic HB, doing a B18A1 Swap.
Went to start prepping the motor and folund that someone broke one of the bolt holes on the motor, the one between the timing belt... so the motor is fubar'd...
Would of been a good motor too...
I found a B18B1... what would i need to do to put the B18B1 in the B18A1's place...
Keep in mind I have ALL the parts for the B18A1, ecu, axles etc...
psychochicken is offline   Reply With Quote
Old 05-22-2006, 01:56 PM   #2
I made the millionth post
hosmer's Avatar
Ride:  03 350z, 03 CL-S, 02 Excursion, 91 CRX Si, 86 CRX Si
Rep Power: 58 hosmer has much to be proud ofhosmer has much to be proud ofhosmer has much to be proud ofhosmer has much to be proud ofhosmer has much to be proud ofhosmer has much to be proud ofhosmer has much to be proud ofhosmer has much to be proud of
Send a message via AIM to hosmer
harness and distributor
Hold it fellas. I'm afraid you're just too darn loud. Next please. BRING THE NEXT GROUP PLEASE.
hosmer is offline   Reply With Quote
Forum Jump
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
