ok my friend just recently swap a Z6 in to his hatch.....but its having problems. frist we thought it was the ECU.....not the problem. then we tried the TPS, still the same.
Heres what its doing, when you hold it steady at about 1400-2500 it wants to stall. and jerks really hard. Any suggestions on what to do? i had the same problem out of a 93 integra changed out the distributor and fixed it. also i beleive the car is throwin codes 2 & 5.... not for sure but we need to check again. Thanks |
code 5 i believe is the map sensor. is that hooked up? is the red tube coming out of the firewall. hook that to the throttle body. code 2 is a faulty ecu but you said thats not the problem so im sure about that. is the timing right?
thanks ill try to re time it and if it dont work, i dont know what to do with it. i know the car should be runnin a P28 ecu, but its being ran by a PM6. no its not runnin VTEC. my buddy is talkin about chippin the ECU and runnin everything that way.
Ride: 1991 CRX Si
I would suggest buying a p28. do it right.
also double check your plugs. make SURE the map sensor is off the firewall and on the TB.(it's the plug with the red, white and green wires). Also check your o2 sensor. I would suggest doing it the easy/right way by buying a P28 and a Boomslang conversion harness. That way you don't have to worry about ghetto-wiring your vtec and o2 sensor wires. |
#6 |
Ride: 1991 CRX Si
Once again, an obd1 ecu is better for tuning, so when/if he goes boost, he WILL need to tune it.
Tell him to just do it right... P28 and a Boomslang harness. It should only be about $200 total. (no more than $80 for ECU. Harness is $115 from boomslang) |
#10 |
or you wanna save some $$$ buy a p06 ecu, convert it to vtec, chip it to run like a p28 and build your own conversion harness. That's the way I did it and I think I spent under $100. All the information is out there to make the harness and how to chip the ecu you'll just have to invest som time in reading up on it.
#11 |
Ride: 1991 CRX Si
thats a very big task for a new person though.
spending an extra $15 on a pre-made conversino harness including vtec and o2 sensor pre soldered, professionally done, heat-shrink wrapped.... it just so much easier. |
| cx with d16z6 engine rev problems | crxsi | HYBRID -> EG-EK / DC | 1 | 09-28-2006 12:06 PM |
| d16z6 in 89 hf... problems. | racapozzi | HYBRID -> ED-EF / DA | 2 | 07-21-2006 07:35 AM |
| F/S A Bigs list of d16z6 And 92-95 Civic parts | Boosted4dr | Parts: For Sale/Trade/Wanted | 31 | 04-10-2005 11:03 PM |
| D16z6 into HF problems | CRX2NR18 | HYBRID -> ED-EF / DA | 4 | 04-24-2004 11:42 AM |
| D16z6 Parts And Sensor. | Sinner | Parts: For Sale/Trade/Wanted | 1 | 07-03-2003 01:16 AM |
