help with my crank pully
Old 09-05-2003, 03:16 PM   #1
Rep Power: 14 serialkilla187 is off the scale
Send a message via AIM to serialkilla187
ok to make a long story short my crank pully came off when i was driving 1 day and now that i got a new 1 and put it on it will only stay on tight for like 2 days then you have to tighten it again and the same over and over so if anyone knows what my problem is any sugggestion are well appriciated....thanx
serialkilla187 is offline   Reply With Quote
Old 09-10-2003, 11:48 AM   #2
sounds like you messed something up man. Try locktite or something? I dont know you're screwed
90 Integra Sedan
B20V 225 / 153
Old 09-10-2003, 12:01 PM   #3
88 C1V1C 53D4N DR1V3R
saturn_boy96's Avatar
Ride:  2006 Suzuki Aerio
Rep Power: 31 saturn_boy96 will become famous soon enough
Send a message via AIM to saturn_boy96 Send a message via MSN to saturn_boy96 myspace
lock tite and make sure your torqueing it to honda spec.
saturn_boy96 is offline   Reply With Quote
Old 09-10-2003, 12:14 PM   #4
Rep Power: 25 MXDesa will become famous soon enoughMXDesa will become famous soon enough
Send a message via AIM to MXDesa
This happened to me too. What u do is, if u have air tools, set the pressure to around 100-115 P.S.I. Put a 17mm socket on the air gun and let that bitch have it. It should tighten it enough to where it would come off again while ur driving. If you dont have an air gun or torque wrench, take it to a shop to do it. Also make sure that u didn't loose the "key" which is a little metal insert that keeps the crankshaft pulley from loosening as the crank spins. Its about half inch long by 1/4 inch tall, small as piece. Good Luck, if that doens't work use locktight.
2003 EP3 Civic SI - Pretty Much Stock (for now)
1990 Eagle Talon TSI Turbo AWD
2005 Kawasaki ZX-6R - 10.58 ET at 137 MPH
MXDesa is offline   Reply With Quote
crank pully not ballanced... CRseX84 General Tech and Maintenance 1 06-26-2004 05:54 PM
Crank Pully coming off.... CRseX84 General Tech and Maintenance 0 06-24-2004 07:39 PM
wanted!!! 90 integra stock crank pully b18burna Parts: For Sale/Trade/Wanted 2 12-25-2003 09:51 AM
frozen crank pully bolt yardrat General Tech and Maintenance 15 12-07-2003 03:09 PM
wanted DA crank pully b18burna Parts: For Sale/Trade/Wanted 2 11-24-2003 07:12 PM
