help please dpfi to mpfi
Old 01-21-2005, 09:46 PM   #1
Rep Power: 0 kit88 is off the scale
HI, I finish my dpfi to mpfi swap on my 88 hatch std, and my car strat with no problem, then I go to rewiew all the connections looking for loose wires I found everthing ok, but when I try to start my car again ¡¡¡ WON´T START!!!!
I doble check evertingh and looks ok, The injectors are working and I got spark, but the car won´t start.
I have 2 weeks trying to fix this with I cant.
Please help, I check all the fuses and are OK.
help
kit88 is offline   Reply With Quote
Old 01-22-2005, 01:42 AM   #2
Rep Power: 59 hcivic.com is on a distinguished road
ok did you wire the injectors correctly?
check the timing?
firing order?
then get a can of ether and spray it in the tb as a friend cranks the car, it the car fires or sputters, it is a fuel issue if nothing happens chances are it is a timing issue,
hcivic.com is offline   Reply With Quote
Old 01-22-2005, 08:57 AM   #3
What he said. Good Luck...
90 Integra Sedan
B20V 225 / 153
Old 01-22-2005, 11:36 AM   #4
check the timing?
firing order?
How can I check the timming, I´m new on this.
Old 01-22-2005, 11:59 AM   #5
Rep Power: 19 racintweek is an unknown quantity at this point
make sure you have your ground on the t-stat housing on, its the ground for the ecu
"sometimes you just have to race"
-Dave Chappelle in D.C.
<div class=\'quotetop\'>QUOTE</div><div class=\'quotemain\'> if one car has more torque and another more power, the one with more power will actually end up having more torque at the wheels</div>-Honda-Tech user
racintweek is offline   Reply With Quote
Old 01-22-2005, 02:54 PM   #6
I check ALL THE INJECTORS AND ARE OK.
CHECK THE GROUND AND IS OK?
WON´T START!!!
Old 01-23-2005, 02:15 AM   #7
Gettin Fuel?
Gettin Spark?
90 Integra Sedan
B20V 225 / 153
Old 01-23-2005, 10:25 AM   #8
Ride:  06 Chevy Silverado
Rep Power: 83 Jeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud ofJeef has much to be proud of
Send a message via AIM to Jeef
Did you connect both yellow/black wires from the old injectors to the resistor box? Try a different ecu, to see if yours is shot. Check for spark by pulling one plug out at a time while cranking the engine have a buddy check to see if there is spark coming from each plug. Don't hold the plug when you do this. Check your timing and plug order. If you don't know the plug order I can try to find a picture with the proper plug order. Did you solder your connections. Verify each connection to make sure none came loose. Check your fuses too.
Ex 89 crx si,91 & 95 Civic owner.
06 Silverado RCSB 20's, 2/4" Belltech lowering kit, waiting for 2 more cylinders, 1.9 more liters, and 208 more hp engine swap.
Jeef is offline   Reply With Quote
Old 01-23-2005, 11:31 AM   #9
cheese9988's Avatar
Ride:  2007 Chevrolet Cobalt SS Supercharged
Rep Power: 31 cheese9988 will become famous soon enough
Do what jeef says and solder your connection if you didn't, even if you get your car running you would not want wiring problems in the future and having to try and figure out which wire gives you the problem.
Is it good when my dipstick is rusty on my jeep?
Linux Mint 6.0
"The only man who makes no mistakes is the man who never does anything. Do not be afraid to make mistakes providing you do not make the same one twice."
Theodore Roosevelt
http://homemodders.com/t188/
cheese9988 is offline   Reply With Quote
Old 01-24-2005, 01:31 PM   #10
Rep Power: 12 dragon2003 is off the scale
Send a message via MSN to dragon2003 Send a message via Yahoo to dragon2003
well i just did dpfi-mpfi and well i haven't got my car back from the shop yet, but i should within a few hours. but are you using an si ecu?
89 Honda Civic Dx
Future Plans:b16a1 swap
dragon2003 is offline   Reply With Quote
Old 01-24-2005, 03:19 PM   #11
inj and firing order
dizzy---4---3---2---1---timing belt
&quot;sometimes you just have to race&quot;
Old 01-25-2005, 01:08 PM   #12
yeah i got my car back, but the only problem is that it would not run, but i got that problem fixed , but now it sounds like a modified nissan 240, what could be the problem?
89 Honda Civic Dx
Old 01-25-2005, 04:09 PM   #13
Do you have a better description of the problem?
Old 01-25-2005, 07:28 PM   #14
well it is miss firing, and i can't figure out what it is, i checked all the wiring and timing, so everything is in order, but when i start the car, the engine has a knocking sound and rocks back and forth. and when i took it for a drive it is lacking power.
89 Honda Civic Dx
Old 01-25-2005, 10:01 PM   #15
Rep Power: 15 DelSlo is off the scale
that sounds like a possible bad ground dragon, check the ground at the tranny and the one from the head to the frame (near power steering pump if equipped)
93' Del Sol
2000 B16A2 swap.
garrett T3/T4 (.48/.60)
Weapons of choice.. Innovate LC1 and Crome Pro
Faze EL Engine management guages.
DelSlo is offline   Reply With Quote
Old 01-26-2005, 12:09 AM   #16
Check your distributor timing.
Old 01-26-2005, 03:56 PM   #17
ok i'll check those
89 Honda Civic Dx
Old 01-26-2005, 09:00 PM   #18
well i checked everything, and the grounds are good, and the timing is good. it runs better, but it just runs sluggish now. And when i lightly hit the gas it sounds good, but when i give it more gas, it back fires and is lacking power. it sounds like something is clogged.
89 Honda Civic Dx
Old 01-27-2005, 07:22 PM   #19
CrazyAzn's Avatar
Rep Power: 17 CrazyAzn is off the scale
that sounds like a timing issue, but then again thats just me.
89 EF build: Poorman's ITR
95 GSR bottom end, .25over b16 pistons Pr3
Zealautowerks compression = 11-8-1
ARP head studs, Stock head gasket
S2 Pro series IM, w/ Hondata intake gasket
Holley 68mm throttle body
ITR 4-1 header, w/ 2.5 in magna flow exhaust ( sounds niceeeee btw)
kteller 2.5 mandrel bend kit.
PnP b16 head w/ dual valve springs and ITR cams
Milled about .030
AEM hybrid CAI
Running obd1 w/ p28 tuned on chrome
Made 178 at churches w/ 2in exhaust and dc 4-2-1 header w/ 2 in collector.
CrazyAzn is offline   Reply With Quote
Old 01-28-2005, 02:55 PM   #20
Rep Power: 0 Get Juiced is off the scale
I had a problem similar to this and it was the two wires i added from the ecu to the dizzy, they weren't shielded wires which caused them to not produce enough signal to and from the dizzy, and it kept throwing the CAS code, or #4. It would start easily sometimes, then other times i would run the battery dead tryin to get it cranked, there probably a good chance this is your problem, what kinda wire are you using and if it is the proper wire its worth getting some new wire to try it anyway.
Get Juiced is offline   Reply With Quote
Old 01-28-2005, 04:32 PM   #21
well i went to the site fourthgenhatch.com and he said that his car was running on 3 cylinders before he went back and soldered all of his connections and that was something i didn't do, i didn't solder the wires that i cut, so could that be the problem? well my car starts up fine, but i just think it could be that i didn't solder them and the signals are jumping. tell me what you think about this.
89 Honda Civic Dx
Old 01-28-2005, 04:37 PM   #22
TTIWWOP
reckedracing's Avatar
Ride:  90 z6-t hatch, 94 Bagged S10, 91 Lifted Mazda
Rep Power: 382 reckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond repute
reckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond repute
didn;t geta chance ot read the whole thread but go through and first pull plug wires one at a time and see if it makes any diffrence, then go back and pull injector plugs one at a time... if you find one that doesn;t make a damn diffrence if its plugged in or not then that could be your problem
I'll blow a hole in your face then go inside and sleep like a baby.
reckedracing is offline   Reply With Quote
Old 01-28-2005, 05:39 PM   #23
well what i did on all of the connections is i just twisted the wires and put heatshrink on them, so what i am thinking is i need to solder and heatshrink them to make a solid connection and get a steady signal.
89 Honda Civic Dx
Old 01-28-2005, 06:11 PM   #24
well Get Juiced did your motor rock back and forward also?
89 Honda Civic Dx
Old 01-28-2005, 06:14 PM   #25
well when the motor rocks back and forward, is it cause by miss firing.
89 Honda Civic Dx
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
