hf to ls
Old 07-02-2009, 09:22 PM   #1
kricket3000's Avatar
Rep Power: 8 kricket3000 is on a distinguished road
Default hf to ls
hey guys, been searching around and i'm looking for a vacuum diagram for a b18a1 into a 88 crx hf. any help would be great, thanks
kricket3000 is offline   Reply With Quote
Old 07-03-2009, 09:50 PM   #2
Old 07-04-2009, 09:13 PM   #3
o well, i'll just buy a neon!
Old 07-06-2009, 12:07 AM   #4
D16SiHatch's Avatar
Rep Power: 33 D16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud of
please god don't do that :|
this is how i have them routed in my b18b1 in my si. not exactly like your a1 but should give you an idea. the blue line is where the map vacuum line would go assuming i didnt have a tb mounted map sensor. the yellow is for the purge solenoid that goes to the evap canister. the thick red vac line outlined with yellow goes from the vac canister, to the top of the throttle body. the dark orange line behind the tb goes down to the vac purge valve. the light blue vac line is for pcv, and on the farthest to the right the brown outlined vac line goes to the fpr.
i included the vacuum routing diagram for the a1 as well.
91 Civic Si
b18b1, I/H/E, 6000k HID kit, 94 teg cluster
Parting mustang out to buy another civic
D16SiHatch is offline   Reply With Quote
Old 07-06-2009, 08:34 PM   #5
if it was not gay i would hug u, thank u vary much
Old 07-07-2009, 11:58 PM   #6
D16SiHatch's Avatar
ha not a prob man. glad i could be of some help
91 Civic Si
