Is the frame liter or its components?
1990 crx SI weighs in at about 2,175 pounds the HFcomes in at about 1,950 pounds the big difference in weight seems to me to be in the motor and the sun roof. Example the HF motor weighs less than the SI motor so if you pull the stock motor ant drop in a b16 the weight not that much different because your changing out the motor(the main reason for weight difference) Drop the sun roof and the advantage of an HF swap should not be that different. Also what is the weight difference of the rear drum brakes compared to the rear disk. I would think the drums would be heavier. I gues the only way to know is to weigh the dam car after the swap. I already broke my bathroom scale.<<<<<<<<<<<<<<just a joke __________________
Is it ever fast enough?<a href=\'http://www.240sx.org/links/hos/pos-crx.jpg\' target=\'_blank\'>click on this pic</a> Tonyd0821 ripped me a new asshole, and all i got was this lousy fucking sig. |
the hf and the si motor weigh basically the same, the weight difference comes in the handling and suspesion upgrades the si comes with, the hf has alluminum rear drums, the si has a sun roof, the si also has more support for the passenger compartment, plus im sure there is more, but just to give you an example.
what handling upgrades does the si have over an hf,dx ? <_<
1990 white crx dx immaculate shell... waiting 1995 black del sol VTEC,jdm B16A, black 15" rota slips, BFG g-force ta kdw's, kyb agx's, eibach pro-kit, tanabe strut bars, tanabe hyper medallion, dc header in 1962 honda launched their famous ad campaign: "you always meet the nicest people on hondas" ...chirp <span style=\"color:#3333FF\">WTB</span> gsr head , ls block, or b20 block. |
the si has bigger front and rear sway bars
#5 |
also has bigger front brakes.... i think..... and rear disk brakes
aslo i had my friends and i did a rear break conversion on his hf. rear drum breaks are steel(not alliminum(sp)) BIG HUNKS OF CRAP- the motor size is very noticeable when you put th si next to the hf. florida-MIKE __________________
#6 |
the motor size is the same it is the same block the only difference is in the intake manifold size which is prolly 5 pounds,
#8 |
Ride: '92 Civic CX
actually, the rear wiper is a few pounds.
Garage: 1992 CX Hatch > Current Money Pit Grave: R.I.P. 1995 Integra GSR R.I.P. 1990 DX Hatch R.I.P. 1990 CRX Si |
#9 | |
Admin with a big stick
Ride: 2003 S2000
#11 | |
Ride: 06 Chevy Silverado
90-91 civic 4drs had the biggest rotors of the the 4th gen. They are an inch bigger. __________________
Ex 89 crx si,91 & 95 Civic owner. 06 Silverado RCSB 20's, 2/4" Belltech lowering kit, waiting for 2 more cylinders, 1.9 more liters, and 208 more hp engine swap. |
#12 | |||
Ride: 2003 S2000
Yes, they did- but only the 90-91 EX models. I didn't say all Civics though- I said all CRXs. :P ![]() __________________
#13 |
I forgot to add the ex part. Thats why I shouldn't be posting after a 17 hour work day. I am an asshat.
| The real affects of wheel weight? Weight in genera | vtec4life | Wheels / Suspension / Tires / Brakes | 8 | 06-24-2004 06:17 AM |
| Automotive Formulas | pissedoffsol | Reference Materials | 0 | 03-01-2004 07:06 AM |
| Unsprung Weight, Part 2 | pissedoffsol | General Tech Articles | 0 | 01-11-2004 08:46 PM |
| Unsprung Weight, Part 1 | pissedoffsol | General Tech Articles | 0 | 01-11-2004 08:46 PM |
| Engine Weight | gatherer | Engine Building | 24 | 01-27-2003 07:15 PM |
