how to tell if vtec is working??????????
Old 04-16-2007, 08:04 PM   #1
jason91si
Ride:  1991 honda civic si b16a
Rep Power: 6 jason22ga is on a distinguished road
Send a message via AIM to jason22ga
Default how to tell if vtec is working??????????
ok heres the deal i dont think my vtec is working so i put a checker on vtec solenoid and revved my car to where vtec kicks in and the checker light didnt come on is there any other way to tell or should the checker light come on if its getting power any help would be appreciated
jason22ga is offline   Reply With Quote
Old 04-16-2007, 08:16 PM   #2
Führer Mod
eg6sir's Avatar
Ride:  Le Car
Rep Power: 382 eg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
eg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
Send a message via AIM to eg6sir Send a message via Yahoo to eg6sir myspace  FaceBook
what motor is it??
DO NOT PM ME WITH TECH QUESTIONS!
XGT: cEElint
Originally Posted by 93civicracer View Post
my dad owned a Chevelle with a hemi that he claimed made 600hp.
eg6sir is offline   Reply With Quote
Old 04-16-2007, 08:56 PM   #3
TheManRSW
Ride:  1995 Honda Del sol Si
Rep Power: 10 TheManRSW is on a distinguished road
Send a message via AIM to TheManRSW
I think you have to be moving. I don't know the speed, but I am pretty sure you can't hit vtec in neutral.
TheManRSW is offline   Reply With Quote
Old 04-16-2007, 10:15 PM   #4
Drake's Avatar
Ride:  1991 CRX DX/ Blacktop ZC 5spd Swap
Rep Power: 251 Drake has a reputation beyond reputeDrake has a reputation beyond reputeDrake has a reputation beyond repute
Drake has a reputation beyond reputeDrake has a reputation beyond reputeDrake has a reputation beyond reputeDrake has a reputation beyond reputeDrake has a reputation beyond reputeDrake has a reputation beyond reputeDrake has a reputation beyond repute
Send a message via AIM to Drake Send a message via MSN to Drake  FaceBook
Is your ECU throwing any codes?
XBL GT: Churched V2
H3, CoD 4, CoD: WaW, Forza 2, H3: ODST, CoD 4: MW 2
МОΛΏΝ ΛΑΒΈ
Originally Posted by 95b16coupe View Post
if you are under 16 and prego, you are a lost cause. you are given a life raft and dropped into the ocean to fend for yourself. if you make it back to society, you get $1,000,000 in Arby's coupons.
Drake is offline   Reply With Quote
Old 04-16-2007, 10:22 PM   #5
Führer Mod
eg6sir's Avatar
Ride:  Le Car
if its a single cam you wont really hear it and you'll barely feel anything during the crossover.. ..
XGT: cEElint
Old 04-16-2007, 10:25 PM   #6
TheManRSW
You could here my z6, but it was very very faint. I agree you feel almost nothing at crossover.
Old 04-16-2007, 11:50 PM   #7
jason91si
my engine is a b16a
Old 04-17-2007, 12:34 AM   #8
TheManRSW
You should hear a noticable difference in pitch at/or around 5600 rpm. The car has to be moving, though. Vtec will not engage if car is not warm and in motion. If you get no sound or power change...Check your oil level, check for good ground continuity from solenoid, check the vtec screen (I advise you to replace gasket after removing, around 15 bucks from your local Honda dealership). If all else fails...splice in and attach a wire and light inside your car (remove after testing, or you are a true ricer). If the light illuminates it means you are getting a signal from your ecu, in which case, the solenoid may be at fault.
Old 04-18-2007, 03:53 PM   #9
Citizen_Insane's Avatar
Rep Power: 51 Citizen_Insane will become famous soon enough
Send a message via AIM to Citizen_Insane
You need 3 things to hit VTEC
1) Correct Oil pressure - if you don't have enough oil, it won't engage.
2) Warmed up engine
3) You need to be loading the engine, won't work in neutral
If your VTEC isn't working, the car will feel gutless at high RPM, it will feel like It stops pulling as hard after 5000 rpm. You won't (or at least shouldn't) feel it engage, but you should notice that the engine pulls hard all the way to redline, I know my b16 does.
No tech questions through PM please!
B16 CRX....you will be missed
Citizen_Insane is offline   Reply With Quote
Old 04-18-2007, 04:23 PM   #10
Führer Mod
eg6sir's Avatar
Ride:  Le Car
2) Warmed up engine
x2 x2
XGT: cEElint
Old 04-19-2007, 01:10 AM   #11
CrazyAzn's Avatar
Rep Power: 17 CrazyAzn is off the scale
OR, you could drive your car around, drop it in to a low gear at low speed. . . .meaning, start out in 1st, then quickly to 2nd, then to 3rd. . . floor the gas and right around the vtec engaugement the engine sound should change and become louder.
I find this works the best, low gear and juts floor it. . . ( dont use like 5th or anything) just make sureyour cars warmed up and you have oil.
89 EF build: Poorman's ITR
95 GSR bottom end, .25over b16 pistons Pr3
Zealautowerks compression = 11-8-1
ARP head studs, Stock head gasket
S2 Pro series IM, w/ Hondata intake gasket
Holley 68mm throttle body
ITR 4-1 header, w/ 2.5 in magna flow exhaust ( sounds niceeeee btw)
kteller 2.5 mandrel bend kit.
PnP b16 head w/ dual valve springs and ITR cams
Milled about .030
AEM hybrid CAI
Running obd1 w/ p28 tuned on chrome
Made 178 at churches w/ 2in exhaust and dc 4-2-1 header w/ 2 in collector.
CrazyAzn is offline   Reply With Quote
Old 04-21-2007, 02:31 PM   #12
Rep Power: 10 danse will become famous soon enough
I have a B16A swapped into a 91 Civic SI and I can hear a click when it kicks in. If you are using a stock ecu then there are several things that have to occur for it to engage. If you are chipped you can turn off the VSS, oil pressure and set the engage rpm.
danse is offline   Reply With Quote
Old 04-21-2007, 02:48 PM   #13
jason91si
the problem is fixed thanks
Old 04-21-2007, 05:07 PM   #14
Führer Mod
eg6sir's Avatar
Ride:  Le Car
why dont you share so other people with this problem might be able to fix it without making a thread
XGT: cEElint
Old 04-22-2007, 02:26 PM   #15
jason91si
my o2 sensors were crossed so it was throwing codes and vtec wont engage if its throwing codes
Old 04-22-2007, 06:14 PM   #16
Got Rice?
801CRX's Avatar
Ride:  89' CRX HF and 90' Civic Si
Rep Power: 27 801CRX is just really nice801CRX is just really nice801CRX is just really nice801CRX is just really nice
Oh well thats good you got it fixed.
I was going to ask you, how in the hell did you put a test(checker) light on the solenoid. And rev your car at the same damn time?
www.supremacyracing.com
801CRX is offline   Reply With Quote
Old 04-22-2007, 06:15 PM   #17
Führer Mod
eg6sir's Avatar
Ride:  Le Car
ummm..
there is a thing called a throttle cable that allows you to give the engine gas from the engine bay.. duh .. or he had someone rev the engine for him
XGT: cEElint
Old 04-22-2007, 06:18 PM   #18
Got Rice?
801CRX's Avatar
God daminnnn it..........I totally spaced out that one, how the fuck did I forget about the cable......fuck fuck fuck fuck fuck fuck.
You got me on that one.
Old 04-29-2007, 07:49 PM   #19
Rep Power: 6 boriquashawn is on a distinguished road
ok. i have a question for you all then. I also just did an engine swap in my 93 civic hatch vx. we dropped in a d15b7 block (non vtec i know) and we put a d16z6 head on it. since my civic is a vx model it was originally a vtec so all the wiring and computer were able to be used on the d16z6 head. i didnt know about an oil restrictor jet in the block (blanco gave me that info) so the vtec didnt work at all. we took the head off and pulled that jet out and it still doesnt work. but i read on this page someone mentioned their o2 sensor? my o2 sensor is bad. could that be the reason my vtec wont kick in? if so the shitty part about that is that the vx civic have the 5 wire o2 sensor and they cost $500 at auto zone. so im screwed for now. but any info would help please. thanks
boriquashawn is offline   Reply With Quote
Old 04-29-2007, 07:58 PM   #20
Führer Mod
eg6sir's Avatar
Ride:  Le Car
start you own thread then.. no need to threadjack
XGT: cEElint
Old 04-30-2007, 06:15 PM   #21
why dont you share so other people with this problem might be able to fix it without making a thread ? DEE DEE DEE!
Thats your own post dumbshit. my question implied directly to what the thread was involved in. Any help from someone would be nice. not smartass comments for no reason. that wont help anyone.
Old 04-30-2007, 06:26 PM   #22
Führer Mod
eg6sir's Avatar
Ride:  Le Car
XGT: cEElint
Old 04-30-2007, 08:02 PM   #23
The Riced Sleeper
ThatGuy4life's Avatar
Ride:  2000 Si w/B18C5-R swap
Rep Power: 45 ThatGuy4life has much to be proud ofThatGuy4life has much to be proud ofThatGuy4life has much to be proud ofThatGuy4life has much to be proud ofThatGuy4life has much to be proud ofThatGuy4life has much to be proud ofThatGuy4life has much to be proud ofThatGuy4life has much to be proud of
myspace
$500 for an o2 sensor???????????
Originally Posted by reckedracing View Post
it takes a strong person to open themselves to criticism, and a weak person to sit behind a computer screen and criticize
Dam, did I just beat u in my Honda? Sure did, now your girl wants to get at me (True Story) "I built it, I drive it, your opinion doesnt matter. It doesn't have to be JDM it just has to be functional." (2nd part of sig. taken from 89CRXZC)
http://racingsouthwest.com/forums/in..._item&CID=1708
ThatGuy4life is offline   Reply With Quote
Vtec Solenoid Troubles RandomTask76 HYBRID -> EG-EK / DC 5 05-20-2009 01:05 AM
b16a swap EG VTEC not WORKING, how to fix? dc2dropx General Tech and Maintenance 4 11-11-2008 08:56 PM
VTEC quit working? 92_gsr_eg ECU's, Electronics, and Tuning 11 02-08-2007 09:43 PM
Vtec not working HELP civic32958 HYBRID -> EG-EK / DC 2 10-28-2004 11:45 AM
