#28 |
Drive it like u stole it
Ride: 88 Ef Hatch/Z6 swap
This write up is wrong I followed ur wiring diagram and it was wrong car didnt run at all so consolted a friend and he made it right for me now my car runs Ill post up pics and the right wires code to follow...
#29 | |
Ride: 1991 CRX Si
Did you follow Boomslang's chart?
I edited the front page. Please look at the letters in BIG font. Quote:
1991 CRX Si 2007 Civic Si Sedan My Engine Swap Write-ups: HG FPR Wheel Smiley Cluster. Adapters. Last edited by Andrew; 11-28-2006 at 08:05 AM. |
#30 |
I used this diagram and my car wouldnt start I just got home from a 14 hour work day so maybe thursday i will look it over and send u the wire connections ok thanks for the help tho
#31 |
Ride: 1991 CRX Si
Your welcome. I'm very sorry if it misled you any.
The main point of the thread was to just show how to actually connect them, not nessesarily to follow my exact wire colors(because for some reason my wires are different colors than reg. obd-1 connectors.- I had 3 to look at, so I got it right, but it's just different colors than anyone else I guess.). Again I'm sorry if I misled you with this post!!! It sounds like you got your car running with the aid of your friend though. Thats the most important thing! -Andrew |
#34 |
Ride: 1991 CRX Si
Yeah, I guess you could re-pin a dizzy connector to obd-0, too.
I will probably eventually repin my obd-0 plug into an obd-1 one(on the harness), but have to figure out how to get these stinkin pins out. I tried it a little bit, but didn't want to damage the wires/pins/connectors. |
#35 |
Ride: 1988 Civic LX>> D16Z6
well couldnt you just cut the female connector from the obd0 dizzy and solder it onto the obd1 dizzy swapping which ever wires you need to.
I guess it would be cleaner to depin the obd0 connector and put the pins into the obd1 connector. my problem is I cant find a obd1 connector anywhere around where I live. Last edited by ceehris; 12-07-2006 at 01:19 AM. |
#39 |
Ride: '91 Civic hatch DX
Good write up!
Concerning the replacement of the plug on an OBD1 dizzy with an OBD0 piece (or vice versa), I believe the actual pins themselves and\or wire gauges are different between the distributors\harnesses. Merely re-pinning in this scenario may not work properly. I may be wrong, I don't have any parts in front of me to check this out, I just remember thinking about something like that when I swapped a Z6 into my 89 CRX Si and used RyWire's OBD0-OBD1 VTEC harness for the conversion. I'm pretty sure a jumper harness like this one is the most practical thing to run as it is plug n play, removable, and time efficient. |
#41 | |
as for the ecu jumper..... yea with that kit it most likely came with the obd0 to obd1 dizzy adapter. too many connectors than needed is what I think of that. |
#43 |
sry to post this so late into everything but i have an obd1 harness and my dizzy is obd2 so if i were to connect the plug from the harness and match it to the plug on the dizzy according to this diagram it should work?
#44 |
Ride: 1991 CRX Si
If I'm not mistaken the plugs on the obd1 and obd2 are the same. You should be able to just plug it up. Right guys?
I'm probably wrong, as I'm an obd0-1 guy, but I'm pretty confident the actual PLUGS are the same, but the wiring may be different, idk. |
#45 |
i dont thikn they are teh same teh solid black/yellow wire adn blue wire are combined with the other sensor wires on the plug for obd-2 as obd-1 has 2 seperate plugs. im pretty sure. im askin is this colour code u provided the right way to wire it?
#47 |
i bought a car with a jdm d15b and it is not reving pass 3500 i tryed new dizzy and ecu still will not work it is throwing a code 4 crank angle sensor and the wires to the dizzy are cut
| dpfi to mpfi? | little88hatch | ECU's, Electronics, and Tuning | 6 | 04-16-2006 03:35 PM |
| b16a1 into 91 civic lx 4dr | svt1.8t | HYBRID -> ED-EF / DA | 27 | 02-17-2006 04:18 PM |
| b18a1 into 91 civic 4 dr. | lickety_slickjj | HYBRID -> ED-EF / DA | 6 | 01-04-2006 01:26 AM |
| 1.5 --> 1.6L CRX swap...no spark..... | E-dogg | General Tech and Maintenance | 1 | 06-16-2005 05:44 PM |
| good sites for stereo installs | WetWilly | Car Audio / Security / Electronic Accessories | 4 | 08-26-2003 12:28 PM |
