iac problems
Old 11-21-2005, 02:10 PM   #1
90sihatch's Avatar
Rep Power: 8 90sihatch is off the scale
i really can't take the surging idle any more and want to get the problem figured out. I tightened the thermo valve, and have tried all the iac's i can get my hands on, but I don't think any of them are correct. The motor was an auto, so the one from the teg doesn't fit right on the manual i.m I put on. I have the civic one on right now and it fits, but the idle surges very badly. So what I want to know is if there is a difference between the civic iac and an iac from an obd0 manual teg. thanks
90sihatch is offline   Reply With Quote
Old 11-21-2005, 03:09 PM   #2
HS RA
eg6sir's Avatar
Ride:  Le Car
Rep Power: 231 eg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
eg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond reputeeg6sir has a reputation beyond repute
Send a message via AIM to eg6sir Send a message via Yahoo to eg6sir myspace
the civic and integra have different bolt patterns.. i have a type r iacv that wouldnt fit on my b16 manifold
DO NOT PM ME WITH TECH QUESTIONS!
Originally Posted by Celerity View Post
Nothing says class like Willie Nelson on your pussy.
MY For Sale thread
eg6sir is online now   Reply With Quote
Old 11-21-2005, 03:13 PM   #3
90sihatch's Avatar
No, the I have the civic one bolted on, the reason the teg one doesn't fit is because it's from an auto. The civic iac bolts on just fine, but it still surges hardcore.
Old 11-21-2005, 04:17 PM   #4
Rep Power: 23 SixtySecondAssassin is off the scale
there are no differences between auto and manual iacvs.
.....deagle.....
SixtySecondAssassin is offline   Reply With Quote
Old 11-21-2005, 06:32 PM   #5
Rep Power: 108 brian11to1 is just really nicebrian11to1 is just really nicebrian11to1 is just really nicebrian11to1 is just really nice
<div class='quotetop'>QUOTE(SixtySecondA ssassin @ Nov 21 2005, 04:17 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
i concur.
90 Integra Sedan
B20B - BROKEN
LSVTEC - BROKEN
PMTR - running strong!
Old 11-23-2005, 01:08 PM   #6
90sihatch's Avatar
I must have gotten the two switched up in the swap. Is there a difference in obd's then because the motor is from a 92 and I'm running obd0. The car actually doesn't surge as much with the civic one that doesn't fit than it does with the integra one. I have also tried one from a friends ls with no results, so I don't think mine is broken.
Old 11-26-2005, 12:00 AM   #7
90sihatch's Avatar
anybody?
Old 11-29-2005, 05:33 AM   #8
Rep Power: 13 thegreat1310 is off the scale
Send a message via AIM to thegreat1310
i had the same problem make sure your baby coolant lines are hooked up corretly thats what pissed mine off
thegreat1310 is offline   Reply With Quote
Old 11-29-2005, 01:34 PM   #9
90sihatch's Avatar
The coolant lines on the iac just got switched around or what?
Forum Jump
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
