im going to buy a motor
Old 09-02-2009, 03:56 PM   #1
Ride:  90 civic ex 4 dr B16
skellagher is on a distinguished road
myspace
Default im going to buy a motor
i am going to buy a d16a6 for like 250 claims less than 100k and says no smoke so i like the idea of picking it up cheap so i can put my car on the road while i have a second motor to build for boost within the next 3 months. but my question is the guy im buying it from said its been sittin for awhile in his shop so that makes me want to bring my compression tester with me to check the compression what numbers should i look for with the tester?
skellagher is offline   Reply With Quote
Old 09-02-2009, 11:20 PM   #2
blasterman87 is on a distinguished road
im not sure about a d series but for a ls b18 a good test is 180, and my b16a has 195-210 across
blasterman87 is offline   Reply With Quote
Old 09-03-2009, 02:56 PM   #3
D16SiHatch's Avatar
D16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud ofD16SiHatch has much to be proud of
these are the compression numbers for the d16a6
Specified values at 250 rpm and wide-open throttle:
Nominal: 1275 kPa (13.0 kg/cm2, 185 psi)
Minimum: 932 kPa (9.5 kg/cm2, 135 psi)
Maximum variation: 196 kPa (2 kg/cm2, 28 psi)
D16SiHatch is offline   Reply With Quote
WTB b18c1/b16 motor and any d series motor with trans!!! Also need a uncut gsr crank tofasttoslowforyou Parts: For Sale/Trade/Wanted 0 04-25-2009 09:24 PM
JDM GSR motor w/ auto tranny, motor mount problems balkey HYBRID -> EG-EK / DC 4 10-30-2008 08:08 PM
Acura Integra B18B1 Motor swap Tranny, ecu,motor 5spd RSS-Bot Auctions 0 11-11-2007 07:13 PM
I have a 99si motor and trans i want to have a nice reliable motor in my DD and have orangeracer Engine Building 17 07-20-2007 04:22 PM
B-series Motor In A 1991 Civic With Hasport Motor std General Tech and Maintenance 3 02-19-2003 01:18 AM
