This is a discussion on intake swaps in the HYBRID -> ED-EF / DA forum
i have a 91 crx si with a 1.6.. the motor blew so i have a 1.5 out of a 90 crx but it is not fuel injected can i swap intakes and make this motor work in my 91
how hard would it be ...
| | #1 |
| i have a 91 crx si with a 1.6.. the motor blew so i have a 1.5 out of a 90 crx but it is not fuel injected can i swap intakes and make this motor work in my 91 how hard would it be and what would i have to do if the intakes will switch?? chris |
| | #2 | |
| Quote:
| | #3 |
| If you swap intakes, you have to do the dpfi to mpfi. Just search that on the web. You can also do a minime swap. search,search,search! good luck |
| | #4 |
| thats i wasnt sure, he said it wasnt fuel injected, and other than fuel injected there is carbeurated. |
| | #5 |
| Its hard to understand what he is asking but if he has a 91 crx si and put the 1.5 liter d series in it the mpfi will bolt right up and he will have to use the si distributor. No need to do an mpfi swap since the si already is mpfi. I dont think the 1.5 is carburated, its probably dpfi. |
| | #6 |
| Im planning on doing something similar to this, so here's my thoughts. You'll need a new Intake Manifold Gasket, get one for the SI intake manifold. Then bolt it on. then bolt up your SI distributor and your are done. |
| | #7 |
| <_< Ok, I guess nobody read his question. YES! You can use the 1.5 motor to replace your blown 1.6 motor. Just swap the manifolds and distributor and everything is exactly the same! |
| | #8 |
| thanks guys putting my motor in tomarrow found a 90 crx hf with a blown motor the guy wants 300.00 for it i have a b18b1 sitting in the garage but didnt know how much trouble it would be to wire up and by the way what the heck is a dizzy?? chris |
| | #9 |
| dizzy=distributor |
Similar Threads | ||||
| GSR and LS Intake Swaps | endlesszeal | General Tech and Maintenance | 1 | 08-07-2004 02:40 AM |
| Which intake for swaps? | get_nick | General Tech and Maintenance | 5 | 03-01-2004 05:11 AM |
| ITR Intake Manifold on a B16a sir2 head | pissedoffsol | General Tech Articles | 0 | 01-11-2004 07:51 PM |
| intake manifolds | CRX_B16B | Engine Building | 16 | 11-03-2003 12:36 PM |
| B18b1 + 5zigen Fireball Catback + ? Intake = Great | beau_safken | HYBRID -> EG-EK / DC | 3 | 02-05-2003 10:19 PM |
