JDM b16 SWAP
Old 11-11-2003, 10:51 PM   #1
Rep Power: 13 Travis is off the scale
Ok i have post a couple of time and i have not got a straight answer yet.
1. My are between 1500-2500 rpm my car idle surges?
2. My check engine light is on and it say code 1 (O2 and i replace it and still not going off and i reset the ecu)?
3. what is the best ecu for my car i think i am gettin a p30 is that one good?
4. i am using my LS ecu, if i replace that ecu with a vtec will the car run better?
5. i also need to know how to run the vacume line in a integra can any one take a pic of the engine tat was a b16 sir1 in a teg 92-93
i have searched and nothing
Travis is offline   Reply With Quote
Old 11-11-2003, 10:56 PM   #2
Rep Power: 13 91dxSiR is off the scale
if its in a92-93 teg and you are using the b16a sir1 then you want the pr3 ecu.
91dxSiR is offline   Reply With Quote
Old 11-12-2003, 12:59 PM   #3
no because that is a obd0 ecu and i need a obd 1 computer
The p30,p71 and p72 all work in this motor for the obd1 use
Old 11-12-2003, 01:37 PM   #4
OMFG, you have the worst typing skills. Please reword the post and change all spelling errors. Than maybe I can lend a hand.
90 Integra Sedan
B20V 225 / 153
Old 11-12-2003, 02:09 PM   #5
Rep Power: 30 StarBellieAngel is off the scale
Send a message via ICQ to StarBellieAngel Send a message via AIM to StarBellieAngel Send a message via MSN to StarBellieAngel Send a message via Yahoo to StarBellieAngel
i have a 92 XSi swap and it came with a pr3 ECU. This motor is OBD1. So as far as i know, IntegraBuildUp is correct.
but what do i know... i'm just a blonde girl.
<span style=\"font-family:Tahoma\"><span style=\"font-size:10pt;line-height:100%\"><span style=\"color:black\">..::Bl<span style=\"color:red\">a</span><span style=\"color:black\">ck Wi</span><span style=\"color:red\">d</span><span style=\"color:black\">ow g</span><span style=\"color:red\">2</span><span style=\"color:black\">::..</span>
<span style=\"color:gray\">swapped~&amp;~ dropped
90 integra LS ~ B16A</span></span></span></span>
<span style=\"color:gray\"><span style=\"font-size:10pt;line-height:100%\">··¤(`×[¤<span style=\"color:red\"><span style=\"font-family:Tahoma\">if you don't like oral sex, shut your mouth!<span style=\"color:gray\">¤]×´)¤··</span></span></span></span></span>
StarBellieAngel is offline   Reply With Quote
Old 11-12-2003, 02:39 PM   #6
Rep Power: 44 MaaseyRacer is an unknown quantity at this point
Send a message via AIM to MaaseyRacer
1. Take a look at your other problems, this is probably why you are idling so high.
2. You might want to replace the O2 sensor anyways, as it probably would not hurt to have a new one.
3. P30 or a chipped p28 would not be a bad choice.
4. This is probably the cause to all your problems. Get another ecu...
5.
2004 Toyota Tacoma
3.4L V6
TRD Package
4WD
MaaseyRacer is offline   Reply With Quote
Old 11-13-2003, 09:34 PM   #7
BMS
Rep Power: 0 BMS is off the scale
Damn...this is off topic, but my car has SO many more vaccuum lines than that. I get tangled in them whenever I try to do anything
BMS is offline   Reply With Quote
Old 11-14-2003, 01:13 AM   #8
Thanks for that diagram and all the help. I guess i just need to get a new computer. I replaced the O2 senser and the code still on. Oh well, i just will get a new computer and see how that goes.
Thanks Travis
Old 11-14-2003, 01:57 AM   #9
Rep Power: 0 87ls/vtecrx is off the scale
your surging might be from low coolant or a bad coolant temp sensor. i have that problem in my hatch right now. is it hard to start when it is cold? and it could be that a vaccum hose has a crack in it also. run your car at an idle and spray carb cleaner on all the vaccun hoses, FPR, fuel injectors, and where the intake manifold meets the head. you might have a leak somewhere.
but definatly try to get your hands on a vtec ecu.
87 crx-built ls/vtec
91 civic-jdm-b16
90 accord-h22
93 civic-h22-turbo
88 323 gtx-awd-turbo
95 integra-ls
&quot;if you didnt have feet, would you wear shoes. then why the hell do some of you wear bra's&quot;
&quot;speed kills! drive a honda, live forever.&quot; bumper sticker on a ford.
www.cosr.com
www.jdmuniverse.com
www.redpepperracing.com
87ls/vtecrx is offline   Reply With Quote
Old 11-15-2003, 08:03 PM   #10
My coolent temp gauge is not reading any thing. i am not sure what the problem is yet, because i had to extend the wires so it to connect. I disconnected one of the wires my gauge pegs out then, if i connect the wires back togather it does not read any thing on my gauge. You think that could be it. It worked on my last motor??
Does any one know of a obd1 Dohc vtec ecu for sale??
Sorry about the typing mistakes
Old 11-17-2003, 04:19 PM   #11
Does any one know if you can use a SOHC V-tec dist. on a b16 and work right??
No, I just get in a hurry and don't check my typing.
Old 11-20-2003, 01:58 PM   #12
No body knows??
Jdm Obd0 B16 Complete Swap 7thgen01 HYBRID -> EG-EK / DC 2 10-29-2009 01:43 AM
b16 swap dragon2003 HYBRID -> ED-EF / DA 11 07-01-2004 03:22 PM
how to swap b16 into a 99 civic ex 2 door? realjdmshit HYBRID -> EG-EK / DC 1 10-22-2003 03:02 AM
B16 Swap Problem methos713 HYBRID -> EG-EK / DC 11 06-14-2003 10:48 PM
B16 Swap Help jdmcrx89 HYBRID -> EG-EK / DC 8 01-03-2003 08:02 PM
