JDM B16 Swap Problems!!
Old 07-29-2006, 12:08 AM   #1
Rep Power: 0 itzkevin is an unknown quantity at this point
Unhappy JDM B16 Swap Problems!!
Hey guys. I have a 92 integra gsr with the original b17 in it. I decided to get a JDM b16 SiR II [obd1] to replace the b17 because it had over 170k miles and felt sluggish. I bought the b16 from a private seller in my area. After finishing the swap, we finally got it to start after a couple a tries. However, we noticed several severe problems. It sounded very rough and nasty. When I drive it, it feels very slow off the line and i cant get past 3500 rpms. When it gets to 3500 rpms, it bounces off like a rev limiter, causing me to have to shift. this problem happens in every gear. Another problem is my rough idle. I re-used the wiring harness and ecu from the b17. Overall, this should be a straight plug and play swap, because their both obd1 engines and I really dont have to mess with any wiring. Right now, I'm trying to figure out if theres something wrong with the engine itself or maybe the swap was done wrong. Please help me with any ideas on what might be causing these problems.. thanks in advance
itzkevin is offline   Reply With Quote
Old 07-29-2006, 10:30 AM   #2
Andrew's Avatar
Ride:  1991 CRX Si
Rep Power: 47 Andrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to beholdAndrew is a splendid one to behold
Send a message via AIM to Andrew
I just had the same problem @ 3500rpms with my mini-me swap.
watch my Video and read the comments in my Thread.
My problem was a loose Distributor wire, which put me into 'limp' mode.
Check all your pin's and wires at your dizzy, then pull the Hazard fuse for 10 sec to
reset your ECU.
Then take it for a drive.
-Andrew
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 07-29-2006, 06:41 PM   #3
reset your ECU.
-Andrew
thanks for your suggestions man. ima try it out in a bit
Old 07-29-2006, 06:43 PM   #4
Andrew's Avatar
Ride:  1991 CRX Si
No problamo.
Let us know how it turns out.
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 07-29-2006, 07:55 PM   #5
No problamo.
wow man. it worked!! no more problem with the 3500 rpms and its not sluggish no more. all i need now is to fix a couple little problems like my idle and stuff. but yeh, thanks a lot man. i almost went thru with putting my old b17 back in today, before i was able to fix this little problem. thanks for saving me the money and time
Old 07-31-2006, 02:13 AM   #6
damnit, this problem seems to be on and off for some reason. after checking the wiring and resetting the ecu, the problem goes away. however, sometimes when i turn off the car and come back to start it up few minutes later, the problem reappears. its frustrating, because i dont wanna have to check all the wiring and resetting the ecu, each time i go to start up the car. any ideas on why its doing this on and off? i'm still throwing codes 14 and 16, which is the IACV and the fuel injector problem. is this happening because i havent gotten rid of the codes? thanks for any help and suggestions
Old 07-31-2006, 08:51 AM   #7
Andrew's Avatar
Ride:  1991 CRX Si
Well, I'm actually having the same problem, yet again.
My IACV is going bad. Fuel Injector system WAS throwing a code, but just checking over wiring and making sure the clips are on the injecter's were clipped down, it went away.
I'm still having this problem off and on as well. My situation is that my connecter itself has a faulty/bent pin-holder-tab thingy, which basically lets my pin slip right out when I plug the dizzy connecter up, So I'm just gonna replace the entire connecter with another one I have laying around.
Stupid wiring... but I'm glad to hear it worked for you too!
1991 CRX Si
2007 Civic Si Sedan
My Engine Swap
Write-ups:
HG
FPR
Wheel
Smiley
Cluster.
Adapters.
Old 07-31-2006, 10:04 PM   #8
Citizen_Insane's Avatar
Rep Power: 51 Citizen_Insane will become famous soon enough
Send a message via AIM to Citizen_Insane
why don't you just rewire it so that it doesn't disconnect any more?
No tech questions through PM please!
B16 CRX....you will be missed
Citizen_Insane is offline   Reply With Quote
Old 08-01-2006, 04:24 AM   #9
Blah blah blah....
MikeBergy's Avatar
Rep Power: 49 MikeBergy is on a distinguished road
Send a message via AIM to MikeBergy
the codes aren't being thrown for no reason. check your wiring continuity on your IACV and injector harnesses.
btw, you still got the b17? I may be interested in taking it off your hands if you live in cali.
-1991 Integra, lots of goodies in an otherwise stock looking motorp; ITR front brakes.
-Xenocron programmable ecu w/datalogging port, LM-1 wideband, and Moates Ostrich are tuning tools of choice.
RIP 2005 Red Yamaha R6
www.m24x.com - Rocket Motorsports: For more technical engine discussions...
Radar will bounce off of a ride that is shiny and you keep clean.
Please don't PM me with tech questions. Use the forums!
MikeBergy is offline   Reply With Quote
Old 08-03-2006, 06:15 PM   #10
Rep Power: 0 jsaludar is on a distinguished road
If you are still having trouble going over 3500 rpm it could your distributor is going bad. If you can replace the distributor and see you can eliminate that from your list of possibilities.
jsaludar is offline   Reply With Quote
Old 08-04-2006, 12:37 AM   #11
well i just bought this p30 ecu yesterday. with this ecu, it lets me go past 3500 rpms. however, my car is still very sluggish and runs pretty shitty
Old 08-08-2006, 06:07 PM   #12
Ride:  89 Civic DX Hatch
Rep Power: 7 chdb2005 is an unknown quantity at this point
Send a message via MSN to chdb2005
my car is doing pretty much the same thing '89 civic HB DX w/ b16a2 sirII" it's sluggish to start but after i get past so many rpms the car jumps forward a couple times then takes off. i was thinking bad dizzy wire(s)
---Chad---
chdb2005 is offline   Reply With Quote
Old 09-08-2006, 09:04 PM   #13
Rep Power: 0 revlimit90 is on a distinguished road
hey guys i had the same prob but not i am allso blown black smoke that smells like strate fuel and cant fig out the prob
revlimit90 is offline   Reply With Quote
Old 09-08-2006, 09:07 PM   #14
first it was the disbuter and then it was then its was the ecu. what is the iavc? that may be my prob!!!!! with black smoke .. cause i know the bis... is the same thing as runnin ricth .thanks
Old 09-08-2006, 09:08 PM   #15
any ideas?
B16 Auto Swap Question 1995EGGuy HYBRID -> EG-EK / DC 9 03-15-2009 03:26 AM
B16 Swap Mount/Wiring Help Needed NexGen91 HYBRID -> ED-EF / DA 5 03-08-2006 09:17 AM
h22a swap and b16 for sale...plus more...LOOK b18_speed Parts: For Sale/Trade/Wanted 6 01-30-2006 08:49 AM
fs b16 swap , itr head so cal stella99si Parts: For Sale/Trade/Wanted 3 06-09-2004 11:51 AM
B16 head swap camelian HYBRID -> EG-EK / DC 1 10-04-2003 03:50 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
