¿GANGSTA GREMLIN?
Ride: 91 CRX si
ok i know this has been covered before but i cant find the correct info,,and im just basically rechecking everything i will need..
i am going to be swapping a b18a1(obd0) into my 1991 civic si(obd0) now i know i will need the mount kit,the ecu(pr4?),the shift linkage, what else will i need?? i know i need to either cut the front crossmember,or get the traction rod setup,,and i need to put a dent in the drivers side bay(or could i just use a 1 groove crank pulley,im not running powersteering or ac) any info would be great __________________
R.I.P BEN LEE2/24/08 we love and miss you http://burnoutbox.activeboard.com/in...BID=127652&p=1 GOOD FAST CHEAP, you can pick only two. fast and cheap isn't good good and cheap isn't fast good and fast isn't cheap |
I'll be back...
Ride: 06 Mazda 5, 91 Civic DX
B Series into an EF probably has the MOST info on the net. How could you not find anything?
Installation instructions for the bolt in mount kit for B-series engines into 88-91 Civic and CR-X __________________
Real Eyes Realize Real Lies |
¿GANGSTA GREMLIN?
Ride: 91 CRX si
ok after rewording my search i came up with some stuff,,but what i really need is a picture of where to put the dent in the framerail,and which throttle cable to use...
#6 |
Ride: 91 crx si & 01 GSX-R 600
what all do you need to finish ur swap?
I have the axles, half shaft, motor mounts, shift linkage, stage 1 racing clutch, light weight fly wheel and the ecu. i used my stock throttle cable. on my 91 crx si When installing the B18a motor you need to beat in part of the engine bay where the alternator rests. i put the dent on the shock tower, about ten inches down a quarter inch deep and about 2 inches wide and 2 inches high. u don't have to cut the front cross member. my motor went in fine and didn't even touch the front cross member. u do have to take a hammer and pound the lip down about 3 and a half inches to get the rear t bracket to bolt in with out rubbing. |
#7 |
¿GANGSTA GREMLIN?
Ride: 91 CRX si
i need mounts,linkage,axles,ecu,and tranny,,im gettin a tranny for $100
thanx for the info i might just hack my linkage though... and im no going to do the swap for awhile unless i can get the parts for cheap,,cuz right now im going through hard times with money __________________
#8 |
yeah i know what it is like not having Money. i have parts for that swap, if you want them just make me an offer. everything is damn near in new condition. when i figure out how to upload pics, ill put up a for sale thread.
#9 |
¿GANGSTA GREMLIN?
Ride: 91 CRX si
well honestly i dont want to make an offer becuz i dont wanna offend you with a lowball offer,,i dont know what theyre worth to you,,jus lemme know how much u are lookin for and ill see if i can do that
#10 |
B series motor mounts $ 80 shipped
Ls half shaft $50 shipped Stage 1 clutch and light weight flywheel $110 shipped ECU $60 shipped axles $100 shipped shift linkage $60 shipped i'll take pics and upload them tomorrow |
#11 |
¿GANGSTA GREMLIN?
Ride: 91 CRX si
ok ill let you know def.
#12 |
Author of the Madness Man
Ride: 1973 Datsun 240z
This bad boy is right up your alley:
b18a1 swap « Project CRX Come on by and leave some comments, would you? __________________
Do NOT PM me with tech questions! Instead, come see my Automotive Addicts Anonymous page for tips and advice! |
#13 | ||
¿GANGSTA GREMLIN?
Ride: 91 CRX si
#14 | |
Glad it helped though ![]() __________________
#15 |
¿GANGSTA GREMLIN?
Ride: 91 CRX si
ok so ive been trying to put this stupid fuckin motor in for about 4 hours now and it just will not fit...i dont know if i have to cut the front mount that was on the corssmember off...but it just will not sit right in the bay...what the hell is wrong
#16 | |
HNFTuning
I dont wanna have to the chance of the trans hitting that front bracket so I took it off. You have to drill the spot welds out of it and it will fall off, alot cleaner than cutting it off. i know you need to beat or knotch the rear crossmember so the rear bracket doesnt hit it when trying to line up the rear mount. From what i get its easier to lower the car onto the engine rather than dropping the engine in from the top. from the top you need to leave the trans mount off put the drivers mount on, swing the engine in at a angle and secure the drivers side loosely, Now install your trans mount on to the transmssion, place a jack under the trans side of engine, jack it up slowly intil the mount slides up into the frame, secure that mount loosely, move you jack to the rear of the trans, this will push the rear of the engine and roll the front fowards into position worj the bracket in the rear into place, bolt it to the rear mount and to the trans. I have yet to do this but seems in my mind this would be the most logical way to do it from the top.....Apparently the dropping the car on the engine works alot better though. Good Luck. |
#17 |
¿GANGSTA GREMLIN?
Ride: 91 CRX si
thanx for the info...i dont think i have the right bracket for the rear,the one that connects the motor to the mount...it waay too long..
is there a differance between the years of integra mounts?? __________________
#19 |
That's the b18b motor, not the b18a1. You need to use the rear mount from the CRX, that should fit properly. As far as the front goes, drilling is definitely the way to go.
You'll also have to hammer in the driver's side of the engine bay a little (don't go killing it now) so the ... was it alternator? ... doesn't rub. I had to pull my b18 out four times to get it right, the last time was to paint the spot that I hammered so it wouldn't rust. __________________
#21 | |
¿GANGSTA GREMLIN?
Ride: 91 CRX si
and i already have the motor in..just waiting on my rear bracket... __________________
#23 |
¿GANGSTA GREMLIN?
Ride: 91 CRX si
ok incase you havent noticed..my sohc hasnt been running for a long ass time...ive been slowly doing this swap,the car hasnt seen the road in atleast 5mnths..before you go flappin your gums learn what game your playin...
seriously i will piss on any car you drive..i dont need an angle grinder for shit..what i do need is the correct mount.. and yes,this is the first swap im doing by myself,and to one of my cars... __________________
#24 |
Führer Mod
what?? speak english
#25 |
Master of the obvious
| Are you covered? | 2000Si | Members' Lounge | 48 | 07-19-2007 04:30 PM |
| The more I talk about bikes... | Celerity | Motorcycles | 69 | 04-16-2007 10:44 PM |
| help me pick a health insurance plan | pissedoffsol | Members' Lounge | 24 | 07-20-2006 12:17 AM |
| Insurance 101 | pissedoffsol | General Tech Articles | 0 | 03-05-2004 12:29 AM |
| random ramblings | pissedoffsol | Members' Lounge | 20 | 08-28-2003 07:05 PM |
