Hey Guys I have a quick question. I am in the process of building a LS/Vtec. I have a 92 LS integra and a 94 GSR Head. We are almost done building, but i need to drive my car. Will my car drive correct if I do not do the wiring for the vtec. I heard that if I don't run the Vtec wire it will run like a regular LS, is this correct? Also question on which ECU should i be using? p72 obd1? Please email me if you can help.
I'll be back...
Ride: 96 DB8, 06 Mazda 5
Rep Power: 174 |
Yeah, it'll just run like an LS if you use your ls ecu. If you try running a vtec ecu and just not wire in vtec, knock, and the iab's, it'll run like shit.
Now, as far as if you should run a p72 or not, that depends on if you are going to use the stock GSR manifold with the iab's. If you do, then the p72 is what you want. If you plan on running an aftermarket intake manifold such as a skunk2, then you could use several other ecu's and have them socketed, tuned, and chipped for your application.
Mercedes-Benz STARt program, here I come... |
#6 | |
I'll be back...
Rep Power: 174 |
Also, you can't replace an ECU with a VTEC controller. The ECU controls all the functions of the car. And running a LS ECU with a VTEC controller would suck because you'll still be limited to the low redline as to where VTEC makes all of it's power up top. |
#7 |
so if i get a p72 obd1 ecu will this plug into my 92 integra plugs or do i need a harness, also then i would just have to find which pin to wire the vtec to the ecu.What about a knock sensor? im just trying to get an idea b/c a shop is doing it but i want to be sure what could happen ect,.
#9 | |
I'll be back...
Rep Power: 174 |
As far as the knock sensor goes, that also depends on what ecu you use. If you use an ECU that looks for it i.e. the p72, p30, p61... Then the shop either has to drill a spot in the LS block and install it or you'd have to get the ecu chipped and have it disabled. I suggest you get all the parts you're going to use then from there you'll be able to see all your options. Do you not trust the shop who's doing the work? They should know what they are doing, at least I hope they know what they are doing...
#10 |
I am using the stock manifold. does anyone know where is a good spot for the Knock Sensor. I still have to get it, is it cheaper/better to get the ecu programed not to look for it? I trust the guy doing it, its just that this is his first ls/vtec swap. I have not gotten the ECU either, but i have seen on **Bay** that are chipped ecu's (p28, p06 ect) anyone use these?
#11 | |
HNFTuning
If you dont wire vtec a LS in another car would wear you ass out on the street/strip. Heres how to wire you vtec....
#12 |
is lol'ing @ you
Depends on how much you trust the tuner. Since you dont have the sensor itll be cheaper to delete it from the ECU. but do you trust the tuner enough to tune your motor without a knock sensor?
#14 |
I'll be back...
Rep Power: 174 |
Get an ecu from here... DIY Tuning Resource Center for Hondata, eCtune, Neptune, Crome, TurboEdit, Uberdata
Tell him what your set up is and he'll point you in the right direction. |
#15 |
What about this ECU? YOU ARE BIDDING ON A FULLY PROGRAMED AND CHIPPED OBD1 p72 SKUNK2 RACE ECU.(NOT JUST CHIPPED LIKE EVERONE ELSE!!) EVERY PERFORMANCE PART ON YOUR CAR WILL GAIN POWER FROM THIS ECU BECUASE UNLIKE THE IT WILL LEARN YOUR CAR AND DETERMINE HOW TO RUN IT BEST FOR MORE POWER!!!! THIS ECU IS PERFECT FOR STREET / STRIP USE. THIS ECU IS DIRECT FIT FOR 92-95 HONDA/ACURA. 96-01 WILL REQUIRE THE OBD2-OBD1 CONVERSION HARNESS($75 UPON REQUEST). THIS ECU IS IDEAL FOR 94-01 INTEGRA GS-R. THIS ECU HAS:
#16 |
I'll be back...
Rep Power: 174 |
STAY FAR AWAY FROM THAT SHIT!!!
'Will learn your car' screams 'I'M FULL OF BULLSHIT'. There is no chip you could get that could run your car properly. Those chips are just a 'guess' so to speak. They make your car run rich as hell and advance the timing way too much. You need someone to tune your car and burn a chip specifically for your motor...end of story. |
#17 |
Yeah thats true bro those ebay chips suck. Thats why they sell so cheap cause they are generic and untuned. Instead of making power you will end up hurting the motor.
| vtec wiring | hazzardboy95 | Civic and del Sol - EG and EK | 5 | 09-14-2008 09:28 PM |
| need help wiring VTEC | JFR32988 | Civic and del Sol - EG and EK | 6 | 05-17-2007 09:42 PM |
| LS/Vtec Wiring Help | NJcivic21 | HYBRID -> EG-EK / DC | 1 | 04-07-2007 09:52 AM |
| HELP ME! wiring for VTEC | blink1_8_2dude | ECU's, Electronics, and Tuning | 3 | 08-04-2003 09:27 AM |
| Wiring Vtec | RFHOMI2U | ECU's, Electronics, and Tuning | 0 | 01-02-2003 06:46 PM |
