Main Relay vs Ecu Question
Old 05-03-2006, 11:50 AM   #1
TTIWWOP
reckedracing's Avatar
Ride:  90 z6-t hatch, 94 Bagged S10, 91 Lifted Mazda
Rep Power: 411 reckedracing has a reputation beyond reputereckedracing has a reputation beyond repute
reckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond repute
ok, so i've got this 90 hatch, DPFI/auto tranny
the thing has a no run issue
the main relay is clicking as fast a rabbits fuck and the brown top injector (upper injector) is firing off like crazy, in unison with the main relay clicking...
i have a suspicion that the ECU has shit the bed, and that is whats making the injector/main relay click so fast like that
its noticeably loud...
i've changed out the brown top injector with 2 other ones, and i've tried 3 diffrent main relays...
the only other obd0 ecu i have is for a manual hatch, it doesn't do the clicking, but it also doesn't start the car...
ideas?
I'll blow a hole in your face then go inside and sleep like a baby.
reckedracing is offline   Reply With Quote
Old 05-03-2006, 03:22 PM   #2
übber ɐɾuıu etarip
Z6CRX's Avatar
Ride:  1995 BMW 318ti, 1985 Honda VF500F(now legal)
Rep Power: 73 Z6CRX has a reputation beyond repute
Z6CRX has a reputation beyond reputeZ6CRX has a reputation beyond reputeZ6CRX has a reputation beyond reputeZ6CRX has a reputation beyond reputeZ6CRX has a reputation beyond repute
Send a message via AIM to Z6CRX Send a message via Yahoo to Z6CRX myspace  FaceBook
<div class='quotetop'>QUOTE(reckedracing @ May 3 2006, 11:50 AM) Quoted post</div><div class='quotemain'>
ideas?
[/b][/quote]
ECU Fuse, and check all your fuses.
My condensor fan fuse crapped out and my car wouldnt start
charged the battery changed the fuse started up
Originally Posted by Celerity View Post
No one hates anyone around here more than people hate Celerity. He's an asshole.
Z6CRX is offline   Reply With Quote
Old 05-04-2006, 01:38 PM   #3
Rep Power: 0 redhothondacrx is off the scale
<div class='quotetop'>QUOTE(reckedracing @ May 3 2006, 10:50 AM) Quoted post</div><div class='quotemain'>
ideas?
[/b][/quote]
ck all engine ground wires,sounds like a bad connection
redhothondacrx is offline   Reply With Quote
Old 05-12-2006, 12:33 PM   #4
TTIWWOP
ok, here's an update
i got the helms and found out that the ECU LED flashing 16 times = a fuel injector problem
and i also ran all the main relay tests as per helms and at least one of the 5 main relays i have is good
the helms i have is for MPFI and its saying to listen for injector clicking
well i know the injector is clicking about 300 times a minute so its pointing back to either the ECU or some other electrical problem
i need the helms for DPFI
Old 05-19-2006, 03:15 AM   #5
skillz2k5's Avatar
Rep Power: 14 skillz2k5 is off the scale
My roomate had the same problem before we converted to MPFI. He pulled an underdash main relay, popped the top off and all the solder points inside were cracked. He heated them up and put a new dot on each one... works fine now. Just something to check not sure if it will fix your prob.
skillz2k5 is offline   Reply With Quote
Old 05-19-2006, 09:46 AM   #6
TTIWWOP
well, thanks for the reply but i've checked the main relay as per helms step by step diagnostics and it checks out...
Old 05-19-2006, 07:32 PM   #7
Rep Power: 16 handlebarsfsr is an unknown quantity at this point
check the map sensor. my relay was messing up and the fuel pump wasnt priming, turned out to be the crappy wiring job i did on my 2.5 bar. theres a fairly large circut, with several sensors on it that causes the relay to kick over like that, one bad wire or sensor on there will make it do that.
handlebarsfsr is offline   Reply With Quote
Old 05-21-2006, 07:15 PM   #8
Rep Power: 0 yebabee is an unknown quantity at this point
I just did a swap for a friend and had the same situation with the clicking, Ended up being a loose ground on the starter. I would look around like the other poster said above for a loose or missing ground.
Honda/Acura swap subharness OBD0/1/2 $25
(includes plug, wiring to ecu, ecu pin (excl. obd2), shielding, instructions
Sensor plug harnesses - IAB, Knock, 2nd O2, VTEC solenoid, VTEC pressure switch, etc $10
Single sensor plugs - IAB, Knock, 2nd O2, VTEC solenoid, VTEC pressure switch etc $5
Distributor Adaptors OBD0-1 $20
ECU Pins OBD0/1 $1 each
HTTP://WWW.HONDAPARTSHERO.COM\
HONDAPARTSHERO@AOL.COM
yebabee is offline   Reply With Quote
Old 05-22-2006, 02:54 PM   #9
TTIWWOP
the motor has several grounds right off the head and valve cover
we put jumper cables directly from the battery negative to the top ear of the distributor as well as one of the valve cover bolts with no change
we ended up getting another DPFI auto ecu from the junkyard on saturday
as the car sits right now, if you turn it over it will turn over and fire every once in a while, like its only hitting on one cylinder
the new ecu = no hitting at all, and the main relay clicks much faster...
still baffled by this car and its driving me crazy
Old 05-25-2006, 12:53 PM   #10
TTIWWOP
well, it turns out that it was the main group of grounds in the engine harness that go to the top of the thermostat housing
apparently the guy who previously owned the car changed the motor and it never started again, becuase he didn't tighten the 10mm bolt...
fucker
thanks for all the replies
